This always happens when I try to install an inventor or anything else. I am a student so I get a 3 year term, so I try getting the software which we have in school (inventor 2020) and the first time I ever did it with 2017, it worked fine but now it keeps saying it's a free trial. what am I missing? I get the email of the serial number and the codes and stuff, I asked someone in the customer service for the second time and this time it didn't work and got confused pretty quickly so now I'm here. please help.
Solved by leowarren34. Go to Solution.
Are you using an Inventor 2020 serial number on Inventor 2020; version serial numbers are not interchangable,
If you need to request the Inventor 2020 SN then go here: https://www.autodesk.com/education/free-software/inventor-professional
You can double check Inventor 2020 is in your account by going to: http://manage.autodesk.com/
Look under products and services -> Inventor -> All version you have assigned will appear below.
If you still encounter issues contact education support as customer support ignore educational accounts: https://www.autodesk.com/education/support
Are you still encountering any issues @Anonymous?
Share a screenshot of what you're seeing?
Are you saying you're not getting an option to put in the serial number?
Hello @Anonymous !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
No, It turns out I was missing some information so my account could not be verified. it's been sorted now. thankyou!
