Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Installation & Licensing
i have problem in opening autocad 2025
7 REPLIES 7
Message 1 of 8
gumaco1991
369 Views, 7 Replies
Hello ,
my laptop is gaming laptop and has high specs..
I cannot open the AutoCAD 2025 ...it will take long time to be opened ...this problem happened 2 weeks ago till now .
any help?
7 REPLIES 7
Message 2 of 8
pendean
in reply to: gumaco1991
Turn off wifi and bluetooth on your laptop (aka put it in airplane mode), does the issue with the software go away when you start it up?
Message 3 of 8
gumaco1991
in reply to: pendean
i did ..but same problem
Message 4 of 8
pendean
Message 5 of 8
Simon_Weel
Doesn't it start at all? Or does it take a long time to load? Any error messages in the Windows Eventlog?
Message 6 of 8
gumaco1991
in reply to: Simon_Weel
No error message … long time to start
Message 7 of 8
mdavis22569
Do a reset to default .. save the settings, but don't add them back just yet.
2nd test, double click on trying to open this test file:
https://autode.sk/3Sq83rv
Mike Davis
Message 8 of 8
Simon_Weel
Could also be corrupt user files. Try renaming folder C:\Users\<name>\AppData\Roaming\Autodesk\AutoCAD 2025 to something like .old and rename registry key hkcu\Software\Autodesk\AutoCAD\R25.0 to .old as well. Now if you start AutoCAD, it will recreate the user files from scratch. If there's no difference, then delete the newly created folder / registry key and rename the .old ones back to their original name.
Administrator Productivity
