I had a problem about flickering moniter screen after installing the AutoCAD2016 program. So, I removed the AutoCAD2016 program with involved several programs through the Window control panel as well as the folders related to the AutoCAD2016. But, I think something is wrong while processing this course. Because when I try to reinstall the AutoCAD2016, It was failed. Actually I reinstalled the AutoCAD2016 several times because of the problem about flickering moniter screen. But I don't had this problems(failed the install program) before. This time, when I reinstall the AutoCAD2016, there was a message in the middle of the installation. The message -[AutoCAD2016 is not found on this computer. You will need to install AutoCAD 2016 to install this product specific pack.] I visited AutoCAD Forum to solve this problem. I run the Virtual Agent and remove the temp folder. I followed the four steps written on the website. I also removed the AutoCAD program folder and registy following this page- [Remove Autodesk Software (Windows)] . However, I can't solve my problem. I attatch the some capture screenshots. I don't know what to do anymore. Please, help me to solve this problem.
[Virtual Agent] https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Installing-Autodesk-prod...
[Remove Autodesk Software (Windows)] https://knowledge.autodesk.com/customer-service/download-install/remove-products/remove-windows-prod...
Hi @5835560,
Check out the troubleshooting steps in this article for the same issue that you are having: Install Error: AutoCAD is not found on this computer.
I hope this helps, let us know how it goes. Thanks.
