Installation & Licensing
I can't install revit 2021
34 REPLIES 34
Message 1 of 35
noelrojas
25890 Views, 34 Replies
I can't install Revit 2021, it gets stuck as shown in the picture.
Tags (1)
34 REPLIES 34
Message 2 of 35
DarrenP
in reply to: noelrojas
try using browser download instead
DarrenP
Message 3 of 35
mdavis22569
Try the following installer
( you need to download all 6)
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_001_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_002_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_003_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_004_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_005_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_006_006.sfx.exe
Mike Davis
Message 4 of 35
noelrojas
in reply to: mdavis22569
Thank you very much! The problem was already solved. I just rebooted my PC and performed the installation again. So, thank you anyway.
Message 5 of 35
mdavis22569
Keep those links if you need them for the future ...
Best
Mike
Mike Davis
Message 6 of 35
noelrojas
Yes, I did. Thank you!
Message 7 of 35
RevitArkitek
I can't install it either on a brand new computer that's never had any Autodesk software installed.  Its not good that you try to install the trial of a software and it doesn't work.  Doesn't really show well.  Plus there is no explanation or anything.  Shouldn't Autodesk fix this?
Message 8 of 35
mdavis22569
in reply to: RevitArkitek
@RevitArkitek
What happens when you try to install it?
How are you installing it?   ( Downloading of the browser method / Install now ?)
Mike Davis
Message 9 of 35
RevitArkitek
I used the link on this page:  https://www.autodesk.com/products/revit/overview?plc=RVT&term=1-YEAR&support=ADVANCED&quantity=1  After running that it downloads another installer, and then that installer downloads more files to install.  Mine was getting hung up somewhere halfway through the download/install process.
Message 10 of 35
Do I also need to install all 6?
Message 11 of 35
RevitArkitek
I tried 3 times using the regular method.  I downloaded the 6 files and then it worked.
Message 12 of 35
RevitArkitek
The problem with this thread is that downloading a bunch of files after you had trouble installing from the actual installer is not a solution!!  Autodesk should fix the actual installer!!  Or at least give us access to a log or something that tells us where the problem may be.
Message 13 of 35
up, had a similar problem, eventually came up with a theory, restarted the download, opened a Task manager terminal, and watched the ethernet process, between 350 and 450mb (of 9.44gb) the internet flatlined.
Now considering I have fibre optic, i doubt that it is my multi billion dollar internet provider, or the modem, more likely autodesk's revit server!
Note: once downloaded the downloaders, used autodesk desktop app, and it maxed out the modem till done!
Message 14 of 35
Hotter_R
Hi @Anonymous
have you used Browser Download?
Sometimes the issue is not the connection speed, it's about the security tools on the way from Autodesk server to your computer (not only on your computer), but at your provider or so.
Rainer Hotter
Technical Support Specialist - Installation & Licensing
Message 15 of 35
in reply to: Hotter_R
I tried all the 6 different types, the web download, the manual download (but all stopped downloading after a few hundred megabytes), but in the end Autodesk desktop app did the install (still going) and maxed the modem! (please put me through to payroll so I can tell them where to send the cheque!)
thanks
Andrew
Message 16 of 35
Same problem here. I can see Revit keeps its standards, even during installation...
Stuck at 4.74 GB, tried Pause Download, but Retry Download does nothing.
Message 17 of 35
did you read the solutions that were provided?
Message 18 of 35
There are 5 solutions marked as solved?
Which one works? I was looking for a solution highlighted in green.
I've canceled installation and I'll try again.
Message 19 of 35
mdavis22569
@Anonymous
Create a new post and let's work through it .....
Mike Davis
Message 20 of 35
2nd attempt.
Administrator Productivity
