I do NOT have rrom on my C:/ drive for Inventor.It is only a 32GB drive and is taken up entirely by windows. Why can't I install the program on my D:/ Drive like everything else?
Welcome to the community.
You can do this. You just also need to make a few changes to your system so that you can perform this duty and get around the space issue. I have a link about this.
Please understand that some parts of the installation files are necessary to be installed on the root system drive. Shortcuts, registry settings, and profile customizations are all examples of this. However, you may be able to make some system changes that will allow you to install your Autodesk product and avoid this error. Please review my KB article for more information:
http://forums.autodesk.com/t5/Installation-Licensing/Out-of-disk-space-during-installation-to-anothe...
Good Luck!
Hello. You should be able to install on a D:\ drive. The only time you may have an issue is if you are trying to break up a suite installer and already have part of the suite installed on your C:\ drive. The installer will want to force the rest of the suite to the same drive to keep the suite together.
Thank you for taking part in our community!
