Installation & Licensing
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. To translate this discussion, select the language.
Post 1 of 4
how to use a single user AutoCAD license
58 Views, 3 Replies
04-21-2017 08:43 AM
How do I register or activate a single user license???
We've normally used network licenses and I've recently purchased two single user licenses.
I've installed these onto two users' machines and one of them can't access it. License not available.
I can't find any good instructions on how to do this. Frustrating.
- Do they need an Autodesk account. I'm assuming they do. She does and she logs on but still has no access.
- Do I need to do something on the management side of things on our account? I think I do, but can't figure it out.
- My account shows two Single Seat AutoCAD but also shows 0 available. I don't get it.
Can someone help please? I have a person not able to work and we are extremely busy.
I've installed 2016 on her machine even though we purchased the 2018 licenses. And yes, I've installed it using the proper 2016 single seat license numbers.
@hardin
Here are the steps necessary:
  1. Log into your Autodesk Account
  2. Go to the Users tab (Located on the navigation bar on the left)
  3. If you're the contract manager but don't need to use the software, you must un-assign the asset from your account first
  4. Create user accounts for the two users that need access to the software
  5. Edit the users access by giving checking the application within their account access pane.
  6. Click Ok.
On the user's computer,
  1. Launch the application
  2. When prompted, choose Enter Serial Number
  3. The user will be prompted for the serial number, then prompted to signin.
    • They need to use the email address associated with the Autodesk Account as you created.
Hope that helps...
Post 2 of 4
Re: how to use a single user AutoCAD license
04-21-2017 08:58 AM in reply to: hardin
@hardin
With single user subscription license, the contract manager must log in to their Autodesk Account and unassigned the license from their account and then assign the use of the license to this given user.  If the user information is not under your company's contract, than you need to add the user first before assigning it to them.
 Mark Lancaster
  , Certified Professional in Autodesk Inventor 2014/2015/Exam & AutoCAD 2014 and not an Autodesk Employee
 Installation | Autodesk Virtual Agent | Autodesk Register Once | Activation/Chat | Microsoft FixitDesktop Sub-Grant User Access | Error 1603 | Autodesk Med Resolu LibrayInventor Reset | Screencast
 Kudos is much appreciated if the information I have shared is helpful to you and/or others
Highlighted
Post 3 of 4
04-21-2017 09:52 AM in reply to: hardin
@hardin
  6. Click Ok.
Hope that helps...
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution
Post 4 of 4
04-21-2017 01:27 PM in reply to: Darin.Green
Thanks.
That's what I though I needed to do, but it wasn't working.
Our reseller, MidWest CADD helped me out.
Turns out someone with the name of Ning Yi was listed as a software coordinator on one of our accounts and had one of the licenses I needed.
We were able to remove the Access from Ning Yi and assign it to my user.
I then removed and deleted Ning Yi from our users because I have no idea who he/she is...
Kinda scary....
