Hello
I want to know how to deduct Token from Autodesk Token-Flex licenses.
If you are running AutoCAD for a certain amount of time (10 minutes, etc.), for example, I want to know the criteria for deducting a certain Token as much as you used a certain amount of time.
Also, I want to know what the exact Token deduction criteria are, such as whether Token will be deducted or not, if AutoCAD is re-runed after a certain period of time.
