help with serial numbers
i m installing my autcad mep 2016 an architecture 2015 both software has same problem i used in past but now i m in problem because i install new window. 64 please help
3ds max is working well.
Please help my id (arch.azhar@yahoo.com)
ennujozlagam
@Anonymous hello, you may try to check it here << click HERE>>. thanks
ara_neresesian
HI
if you have anti virus on you pc try to disable it during installation .
I had same problem
Please select the Accept as Solution button if my post solves your issue or answers your question
GOOD LUCK
Mark.Lancaster
@Anonymous
May I ask where you got these serial #s from that's located in the install document you have opened?   They look like non-standard issued serial #s and ones (666-69696969) that are issued when someone is trying to crack the code.  In addition Autodesk doesn't provide serial #s in a notepad/text document.
Mark Lancaster
