HELP! Users are getting "Failed to Acquire License" error
Message 1 of 10
Had an update to 2023 apps over the weekend and we have a couple users get the following licensing error:
This is coming up on all their Adesk apps and thus are dead in the water.
We've attempted the fix shown here:
After updating licensing configuration Vault client fails to launch with message "Error 319 failed t...
But no luck.
Reseller has been unresponsive & we need to get them up and running again.
Suggestions?
Replies (9)
Message 2 of 10
rushabhthakkar_910
@Anonymous, have a look at this..!! https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Failed-to-acquire-a-license-Please-restart-the-product-A-Vault-Troubleshooting-Guide.html
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 3 of 10
@rushabhthakkar_910  Thank you. We've worked thru a few of those with no resolution, I have the user going through any other steps as we speak. Will let you know the outcome.
Thanks again.
Message 4 of 10
mdavis22569
@Anonymous
Check the EE post .. I think Neil posted about this ...
outside of this:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Failed-to-acquire-a-license-Please-restart-the-product-A-Vault-Troubleshooting-Guide.html#:~:text=Check%20the%20license%20server%20to,Vault%20Professional%20license%20is%20required.
Mike Davis
Message 5 of 10
karthur1
I was having the exact same issue on VP 2022.  I had to uninstall/reinstall to resolve this problem.
Message 6 of 10
mdavis22569
@karthur1  @Anonymous
I just messaged Neil Cross about it
Question, do you both have the New Autodesk Access or still the older ADA?
Mike Davis
Message 7 of 10
karthur1
If you talking about the new AD Desktop App, yes that is what I have installed.
Message 8 of 10
Reading thru that post, we've attempted basically everything listed that applies. But the standout I see is they never uninstalled the 2018 client when they updated to 2023. I have a good feeling that's the cause.
I've always uninstalled older versions, at least the Vault Client prior to a new install.
We're going to give that a try on one of the users to see if that does the trick.
Back with an update soon.
Thanks all.
Message 9 of 10
I don't see either on any of the users systems as of yet. Things are are very locked down, almost to the point of a government facility, so downloads and extras are tightly controlled, I can't even get to some Adesk pages unless I use my phone and off their network....fun stuff.
Message 10 of 10
Update on this.
One user I found out seems to have a known "problem child" system and always needs special attention for downloads, etc. The 2023 change over install took 3 attempts before it completed. As far as his Vault Client, yes, they left the 2018 version on everyone's systems. Once 2018 was uninstalled and 2023 reinstalled, all seems to be working fine. IT wasn't aware best practices are to uninstall the older releases, especially Vault Client prior to the new install.
So, IT is now planning on doing an uninstall of 2018 apps, leaving a few specific stations with such still available just in case (without the Vault Client), and then repair or reinstalling Vault Client 2023 to fix this issue.
We also found a very similar error and were able to fix that by having the user log out of their Adesk account, reboot and manually log back into the Adesk account.
So things here are finally looking up. Considering they went into this large jump update kinda blind, it went fairly smooth and only a handful of issues. Some are, of course operator error and bad practices. But that's why they brought the Angry Elf in to clear up...;)
Thanks everyone for your help!
