HELP!!! SAVE ME!!! Cannot Open Civil 3D - Says "License Checkout Timed Out" (All Updates have been Applied)
clemay9S6TU
clemay9S6TU
For some reason, I cannot open Civil 3D. It gives me a message that says License heckout Timed Out. And there are only 2 options which are shown below. Can someone point me in the right direction to resolvre this as i am unable to work at this time.
Thanks in Advance
System Model Dell OptiPlex 7080
System Type Win10 Pro x64-based PC
Processor Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz, 2904 Mhz, 8 Core(s), 16 Logical Processor(s)
Memory (RAM) 64.0 GB
Graphics NVIDIA GeForce GTX 1660 SUPER
Solid State Drives (Highly Recommend id freezing issues are a concern)
Size 1.82 TB (2,000,363,188,224 bytes)
Free Space 1.29 TB (1,420,986,601,472 bytes)
rkmcswain
The troubleshooting tool here has worked for us in the past
mdavis22569
What I share on this error daily:
Have you seen the following article about this error:
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
On this article page, there is a troubleshooting form. Have you seen this
https://autode.sk/32xqOyu
We also want to make sure all of the Autodesk updates showing in the Autodesk Desktop app are installed .. for both AutoCAD and Autodesk products (licensing)
Also:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-product-licens...
As of late, if it was working and this is a new issue, I've been seeing Firewall / Access issues, please verify the following are done:
Which URLs/Protocols need to be white-listed for Autodesk Subscription Licenses
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U...
How to set up antivirus (AV) exclusions to improve the stability and performance of Autodesk software
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Are-there-antivirus-excl...
Mike
Mike Davis
Nabil_GergesWA26M
Community Visitor
Community Visitor
License checkout
mdavis22569
@Nabil_GergesWA26M
Try installing this:
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/6IFPpIksTDfsCzp1JwIH5k.html
Review the Connection Tab and see if anything is blocked.
Mike
Mike Davis
