For some reason, I cannot open Civil 3D. It gives me a message that says License heckout Timed Out. And there are only 2 options which are shown below. Can someone point me in the right direction to resolvre this as i am unable to work at this time.
Thanks in Advance
What I share on this error daily:
Have you seen the following article about this error:
On this article page, there is a troubleshooting form. Have you seen this
We also want to make sure all of the Autodesk updates showing in the Autodesk Desktop app are installed .. for both AutoCAD and Autodesk products (licensing)
Also:
As of late, if it was working and this is a new issue, I've been seeing Firewall / Access issues, please verify the following are done:
Which URLs/Protocols need to be white-listed for Autodesk Subscription Licenses
How to set up antivirus (AV) exclusions to improve the stability and performance of Autodesk software
Mike
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
