I'm a student. I have installed Revit 2015 many times but failed. And it always stopped when it show installing Microsoft Visual 2005 C++. So I opened the log. and it showed
"Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603"
"Installing Microsoft
Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk
Revit 2015\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a
/T:C:\windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i
vcredist.msi /qn /l*v C:\Users\USER\AppData\Local\Temp
\vcredist_x64_2005.log"" "
Please tell me how to solve? THX~
Can you try running that install manually. Launch the executable that it noted in the log
C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2005\vcredist_x64.exe
Run that and try to install. If it fails it should give you an error number that would be searchable on the microsoft website.
