I have installed Autocad 2014 last few months successfully, but today while installing Revit 2015, it said "Installation completed. Some products failed to install." and it's related to error 1619 and 1603 problem. I've checked this forum but I can't really understand what to do exactly. Please help...
2014/7/18:19:44:27 Carol NAMNAMBEAN Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603 2014/7/18:19:44:31 Carol NAMNAMBEAN Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/18:19:45:29 Carol NAMNAMBEAN Rollback Autodesk Material Library 2015 Succeeded 2014/7/18:19:45:33 Carol NAMNAMBEAN Rollback Autodesk Workflows 2015 Succeeded 2014/7/18:19:45:48 Carol NAMNAMBEAN Rollback Autodesk® Revit® 2015 Language Pack Succeeded 2014/7/18:19:50:13 Carol NAMNAMBEAN Rollback Autodesk® Revit® 2015 Succeeded 2014/7/18:19:52:11 Carol NAMNAMBEAN Rollback Autodesk® Revit® Content Libraries 2015 Succeeded 2014/7/18:19:52:20 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2014/7/18:19:52:26 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2014/7/18:19:52:32 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2014/7/18:19:52:35 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2014/7/18:19:52:40 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2014/7/18:19:52:46 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2014/7/18:19:52:52 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2014/7/18:19:52:56 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2014/7/18:19:52:56 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2014/7/18:19:52:56 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619 2014/7/18:19:52:56 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Solved by TravisNave. Go to Solution.
I've been trying to install Revit 2017, but apparently, it keeps showing me Error 1619.
Some of the products failed to install. I've attached my setup log for your reference.
Thanks a bunch for your help beforehand!
Geoffrey
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Thanks for attaching your log, which appears to indicate that a Microsoft Visual C++ 2008 SP1 Redistributable failed to download or install.
Whereas it's possible that the link to the prerequisite was down, it's more likely that your machine already has a newer version installed. Windows won't allow installation of an older version than what's already installed. Your best bet may be to remove the later version from your machine and then try the Revit install. Guru Travis Nave covers this in detail here:
HTH...
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
WARNING: This is a worldwide public user community and it's important that you do not include/share your serial # in your posting/attachments. I will have the moderator remove your serial # in order to protect your information. For the future please keep that rule in mind.
Thank you for sharing your installation log file. Like @cadmgr has indicated your installation is failing based on that information. However in sharing your log file you have also shared your serial # with everybody as well.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@ Mark.Lancaster
Thank you very much for your warning! I will be more careful next time.
I did try out the link that @Anonymous gave, it does not work for me as well. I tried uninstalling all the Microsoft Visuall C++ and re-install it using the setup.
I also tried to tweak the setup.ini to bypass the pre-requisite checking. It does not work as well.
Maybe I did it wrong.
Please advise on what I can do to make it work.
Thank you very much for your help!
Geoffrey Tanudjaja
You may be referring to the link inside "Solution #1" on the first linked page. That one appears to lead only to a general knowledgebase search area. You're in the right place now, as folks here have dealt with this issue.
Can you post from your latest install log just the chunks that refer to the failing portion of the install attempt?
This is my latest error:
2016/5/28:13:28:03 User NICHOLASO-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\User\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/5/28:13:28:21 User NICHOLASO-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/5/28:13:28:21 User NICHOLASO-PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\User\AppData\Local\Temp\vcredist_x86_2015.log
2016/5/28:13:28:26 User NICHOLASO-PC Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/5/28:13:28:26 User NICHOLASO-PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\User\AppData\Local\Temp\vcredist_x64_2015.log
2016/5/28:13:28:27 User NICHOLASO-PC Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/5/28:13:28:27 User NICHOLASO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\User\AppData\Local\Temp\vcredist_x64_2005.log"" "
2016/5/28:13:28:41 User NICHOLASO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2016/5/28:13:28:41 User NICHOLASO-PC Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/5/28:13:28:41 User NICHOLASO-PC Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/5/28:13:28:41 User NICHOLASO-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Geoffrey
We are talking here about PrDSu 2015 deployed via AdminImage.
This AdminImage deploys ONLY:
- Inventor 2015 SP2u5
- Mechanical 2015 (no SP)
All other countermeasures are taken (enough disk space, admin user triggering the command, MS FixIT to clean uninstall previous modules...)
Inventor installs perfectly.
Nevertheless the setup of Mechanical always ends up with:
MSI (s) (3C:70) [09:32:30:550]: Note: 1: 1708 MSI (s) (3C:70) [09:32:30:550]: Product: AutoCAD Mechanical 2015 - English -- Installation operation failed. MSI (s) (3C:70) [09:32:30:550]: Das Produkt wurde durch Windows Installer installiert. Produktname: AutoCAD Mechanical 2015 - English. Produktversion: 19.0.48.0. Produktsprache: 1033. Hersteller: Autodesk. Erfolg- bzw. Fehlerstatus der Installation: 1603. MSI (s) (3C:70) [09:32:30:550]: Attempting to delete file C:\Windows\Installer\59c17.mst MSI (s) (3C:70) [09:32:30:550]: Attempting to delete file C:\Windows\Installer\59c18.mst MSI (s) (3C:70) [09:32:30:550]: Deferring clean up of packages/files, if any exist MSI (s) (3C:70) [09:32:30:550]: Attempting to delete file C:\Windows\Installer\59c17.mst MSI (s) (3C:70) [09:32:30:550]: Unable to delete the file outside of the engine. LastError = 2 MSI (s) (3C:70) [09:32:30:550]: Attempting to delete file C:\Windows\Installer\59c18.mst MSI (s) (3C:70) [09:32:30:550]: Unable to delete the file outside of the engine. LastError = 2 MSI (s) (3C:70) [09:32:30:550]: MainEngineThread is returning 1603 MSI (s) (3C:64) [09:32:30:566]: RESTART MANAGER: Session closed. MSI (s) (3C:64) [09:32:30:566]: No System Restore sequence number for this installation. === Logging stopped: 21.07.2016 09:32:30 === MSI (s) (3C:64) [09:32:30:566]: User policy value 'DisableRollback' is 0 MSI (s) (3C:64) [09:32:30:566]: Machine policy value 'DisableRollback' is 0 MSI (s) (3C:64) [09:32:30:566]: Incrementing counter to disable shutdown. Counter after increment: 0 MSI (s) (3C:64) [09:32:30:566]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (3C:64) [09:32:30:566]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (3C:64) [09:32:30:566]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2 MSI (s) (3C:64) [09:32:30:566]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2 MSI (s) (3C:64) [09:32:30:566]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1 MSI (s) (3C:64) [09:32:30:566]: Restoring environment variables MSI (s) (3C:64) [09:32:30:566]: Destroying RemoteAPI object. MSI (s) (3C:0C) [09:32:30:566]: Custom Action Manager thread ending. MSI (c) (1C:28) [09:32:30:566]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: 1 MSI (c) (1C:28) [09:32:30:566]: MainEngineThread is returning 1603 === Verbose logging stopped: 21.07.2016 09:32:30 ===
Any idea?
...since I found it myself I will post the solution as well. It might help somebody.
You NEED TO HAVE DotNetFx 4.5.x
If by some case, you have the 4.6 because you are convinced that 4.6.x is a valid replacement of 4.5.x, silent install will fail, and no logfiles will be there to tell you.
In this case, if you are deploying ONLY ONE VERTICAL (as for example in my case only ACAD Mechanical), you can also integrate the SP in the deployment.
Hope it helps...
@TravisNave got a customer with this exact issue and disabling the BIM360 add in from the install worked a treat 🙂 However the SketchUp Import plugin now seems to be causing the same issue. Installing BDSP 2016, SketchUp import plugin is where it comes up with the error have you come across that before?
Thanks!
Can you provide the installation log files...
Mark Lancaster
I have not particularly experienced this error. But I suspect you can probably do a custom install and deselect it as well. Might be worth drilling down. If you have any log files like Mark suggested, that would be great too.
I have a simiar issue and cannot install Revit 2017.
I have turned off my Firewall and uninstall my antivirus.
I also deleted the temp files af found on other pages.
I also tried to uncheck the BIM 360 and Formlt 360 when doing the installation.
I noticed these errors in the log file:
1)
2016/10/23:18:51:25 Anca ANCA-PC Installing Autodesk® DYNAMO™ Add-in for Revit® 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{1EBADAEA-1A0F-40E3-848C-0DD8C5E5A10D},DXSETUP.exe,;;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/23:18:51:28 Anca ANCA-PC Install Autodesk® DYNAMO™ Add-in for Revit® 2017 Failed Installation aborted, Result=1603
2)
2016/10/23:18:54:02 Anca ANCA-PC Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/10/23:18:54:02 Anca ANCA-PC Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Related to the first, I couldn't find to unselect that Dynamo in the installation in order to skip it.
Related to the seccond, I tried uninstalling Visual C++ 2015 before running the install again but still didn't worked.
I have attached the full log file.
Can you please help?
Thank you,
Welcome to the community... Although you are getting 1603 and 1619 errors the installation log file indicates you are using the web installer
This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include your personal information such as your serial #. This is a world wide user forum and that type of info should not be included in your posting. Granted the installation log file helped us to determine your root cause (but it did contain your serial #)... So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
Mark Lancaster
Pleased to meet you.
Thank you for the quick response and the heads up regarding the serial.
I followed your steps and tried to reinstall but still the same errors.
I attached the log file and as you said, I removed the serial.
Thank you for telling me that it was shown in the log file.
Hello
Can someone help me out please? I have gone thru forum after forum trying to figure out why my install keeps crashing when I get to trying to install Dynamo add-in, but nothing seems to help. Error log below. Thanks in advance.
2017/9/28:10:46:45 wmootrey R90JEDCU Path_Length: 155
2017/9/28:10:46:45 wmootrey R90JEDCU Current Directory C:\Users\wmootrey\AppData\Local\Temp\_AIF144.tmp
2017/9/28:10:46:45 wmootrey R90JEDCU Launch
2017/9/28:10:46:45 wmootrey R90JEDCU Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\wmootrey\AppData\Local\Temp\_AIF144.tmp\Setup\RevitSetup.dll
2017/9/28:10:46:45 wmootrey R90JEDCU Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/9/28:10:46:47 wmootrey R90JEDCU Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\wmootrey\AppData\Local\Temp\_AIF144.tmp\Setup\RevitSetup.dll
2017/9/28:10:46:47 wmootrey R90JEDCU Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/9/28:10:46:48 wmootrey R90JEDCU PageOpen LaunchDialog
2017/9/28:10:47:16 wmootrey R90JEDCU PageOpen LicenseDialog
2017/9/28:10:47:18 wmootrey R90JEDCU PageOpen ProductInfoDialog
2017/9/28:10:47:18 wmootrey R90JEDCU PageOpen ProductSelectionDialog2
2017/9/28:10:47:25 wmootrey R90JEDCU PageOpen FullProgressDialog
2017/9/28:10:47:25 wmootrey R90JEDCU Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\wmootrey\AppData\Local\Temp\vcredist_x86_2015.log
2017/9/28:10:47:25 wmootrey R90JEDCU Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/9/28:10:47:25 wmootrey R90JEDCU Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\wmootrey\AppData\Local\Temp\vcredist_x64_2015.log
2017/9/28:10:47:25 wmootrey R90JEDCU Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/9/28:10:47:25 wmootrey R90JEDCU Installing Autodesk® Revit® Content Libraries 2017: TRANSFORMS=":en-us.mst;C:\Users\wmootrey\AppData\Local\Temp\_AIF144.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/28:10:52:46 wmootrey R90JEDCU Install Autodesk® Revit® Content Libraries 2017 Succeeded
2017/9/28:10:52:46 wmootrey R90JEDCU Installing Autodesk® Revit® 2017: TRANSFORMS=":en-us.mst;:all.mst;C:\Users\wmootrey\AppData\Local\Temp\_AIF144.tmp\x64\RVT\RVT-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/28:10:53:55 wmootrey R90JEDCU Install Autodesk® Revit® 2017 Succeeded
2017/9/28:10:53:55 wmootrey R90JEDCU Installing Autodesk Workflows 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/28:10:53:56 wmootrey R90JEDCU Install Autodesk Workflows 2017 Succeeded
2017/9/28:10:53:56 wmootrey R90JEDCU Installing Autodesk® A360 Collaboration for Revit® 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/28:10:53:59 wmootrey R90JEDCU Install Autodesk® A360 Collaboration for Revit® 2017 Succeeded
2017/9/28:10:53:59 wmootrey R90JEDCU Installing Autodesk® Personal Accelerator for Revit® 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/28:10:54:01 wmootrey R90JEDCU Install Autodesk® Personal Accelerator for Revit® 2017 Succeeded
2017/9/28:10:54:01 wmootrey R90JEDCU Installing Autodesk Material Library 2017 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/28:10:54:18 wmootrey R90JEDCU Install Autodesk Material Library 2017 - Low Image Library Succeeded
2017/9/28:10:54:18 wmootrey R90JEDCU Installing DXSETUP.exe: "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\x64\Tools\DirectX\DXSETUP.exe" /silent
2017/9/28:10:54:29 wmootrey R90JEDCU Install DXSETUP.exe Succeeded
2017/9/28:10:54:29 wmootrey R90JEDCU Installing Autodesk® DYNAMO™ Add-in for Revit® 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{1EBADAEA-1A0F-40E3-848C-0DD8C5E5A10D},DXSETUP.exe,;;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/9/28:10:54:31 wmootrey R90JEDCU Install Autodesk® DYNAMO™ Add-in for Revit® 2017 Failed Installation aborted, Result=1603
2017/9/28:10:54:31 wmootrey R90JEDCU Rollback DXSETUP.exe Failed Failure is ignored, Result=1619
2017/9/28:10:54:32 wmootrey R90JEDCU Rollback Autodesk Material Library 2017 - Low Image Library Succeeded
2017/9/28:10:54:34 wmootrey R90JEDCU Rollback Autodesk® Personal Accelerator for Revit® 2017 Succeeded
2017/9/28:10:54:36 wmootrey R90JEDCU Rollback Autodesk® A360 Collaboration for Revit® 2017 Succeeded
2017/9/28:10:54:36 wmootrey R90JEDCU Rollback Autodesk Workflows 2017 Succeeded
2017/9/28:10:55:34 wmootrey R90JEDCU Rollback Autodesk® Revit® 2017 Succeeded
2017/9/28:10:55:52 wmootrey R90JEDCU Rollback Autodesk® Revit® Content Libraries 2017 Succeeded
See the solution as pointed out in this forum posting.
Mark Lancaster
