Andrew -
This is really hard for me to answer remotely as I have NO idea how your proxy server is configured, but...
Take a look at (in IE) tools -> Internet Options -> Connections -> Lan Settings -> Check to see if Use a proxy server for you lan is
checked, and if the address and port boxes are filled out, then click Advanced and see if the Use proxy same server for all
addresses is checked. If it is and it's not working, your proxy config is different than ours.
You also mention a firewall in the post ("with firewall settings") Do you have a separate firewall or are you using proxy as the
firewall?
jason martin
frankfurt-short-bruza
Member of the Autodesk Discussion Forum Moderator Program
"Andrew" wrote in message news:2628167F4C8E97674A73AE2A13867026@in.WebX.maYIadrTaRb...
> I am trying to get the save to FTP site to work through our proxy server,
> however I cannot figure out how to do this. Our FTP server is located on the
> outside of our proxy.
> At the moment, I cannot get IE to upload through our proxy and assume that
> Autocad and its friends use the IE settings for FTP. Using wsFTP with
> firewall settings set up works fine.
> Is there anything in the registry that I can modify to get this to work?
> I tested this and have no problem getting this to work on the outside of the
> proxy, however I need to bring the client back onto the inside network for
> safety.
