Installation & Licensing
Flow Design Fatal Exception for Mac
4 REPLIES 4
burnfordm
528 Views, 4 Replies
I recently purchased the MacBook Pro (2016) touch with Radeon 450 graphics card. When I first install Flow design it asks me to allow unidentified developers through, which I can do and so Flow design installs. However when I try to open flow design I get a Fatal Exception message and the programme has to quit. Is there anything that can be done to solve this issue? Attached are two photos: the first one I can bypass by changing system preferences. How do I solve the second error?
Thank you
4 REPLIES 4
Mark.Lancaster
in reply to: burnfordm
@burnfordm
Am I missing something here...  Autodesk Flow Design is not a MAC OS supported product.
Mark Lancaster
burnfordm
in reply to: Mark.Lancaster
Hi Mark,
From contacting Autodesk they said is was supported on Mac systems? I am either Being very stupid or doing something wrong?
Mike
Mark.Lancaster
@burnfordm
I'm not a Flow Design or MAC OS user.  I will not have the answer for you and most likely no one here will either..  Its not a common Autodesk product that gets supported here but I did find an article indicating MAC OS was supported now.   But I also found a posting that its not supported under the 10.12 version OS.  Check with the actual users and see if they know..
Mark Lancaster
burnfordm
Thank you for your help
regards
Michael Burnford
Administrator Productivity
