I am trying to install LMTOOLS with a single licensing server onto a Windows 2008 Standard server. We have 4 licenses of AutoCAD 2007. The install went OK, and I think that the license creation worked, but when I configure LMTOOLs and Perform a Status Enquiry, I get the following error:
Status
Flexible License Manager status on Thu 1/29/2009 14:08
[Detecting lmgrd processes...]
License server status: @clarkapps
License file(s) on clarkapps: C:\Program Files\Autodesk Network License Manager\License\ACD2007clarkapps2.lic:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: clarkapps
License path: @clarkapps
FLEXnet Licensing error:-15,570
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
It appears to be referencing the correct license file. I've added port 2080 (which is referenced in the license file) to the Windows Firewall and still no dice. When I try to manually start the Flexlm service from Services, I get an error that the service did not respond to the start or control request in a timely fashion within a few seconds of hitting start.
Any thoughts would be greatly appreciated.
Thank you,
Christine
