Installation & Licensing
finding so many errors and cant fix it
6 REPLIES 6
516 Views, 6 Replies
WhatsApp Image 2020-01-15 at 17.18.32.jpegWhatsApp Image 2020-01-15 at 17.18.39 (1).jpegWhatsApp Image 2020-01-15 at 17.18.39.jpeg
6 REPLIES 6
Alfred.NESWADBA
seems you have issues with your Internet connection, your antivirus or your available harddisk space.
Try to use the browser download method as described >>>here<<< and before you start the installation make sure you have full admin permissions and you have disabled your antivirus software.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
rkmcswain
Don't rely on the combination "download and install" method, which unfortunately is the default I believe.  Download the full set of install files (usually one or two files) and then run the setup.exe.
R.K. McSwain     | CADpanacea | on twitter
Dear sir, while installing autocadd many errors are coming such as , Error 1308,source file not found
please suggest me to resolve such errors.
Alfred.NESWADBA
Make sure your workstation matches the system requirements >>>click<<<
Use method "Browser Download" to download the complete installation media >>>click<<<
Make sure you have full admin permissions, you have disabled antivirus, you have cleaned up your C:\Autodesk folder
Then right click the downloaded (first) exe-file ==> "start as administrator" ... follow the instructions.
- alfred -
Alfred NESWADBA
I take this post is related to: https://forums.autodesk.com/t5/installation-licensing/while-installing-autocad-2020-many-errors-are-...
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Administrator Productivity
