Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
fatal error: unhandled e0434352h exception at dea83b29h
9 RESPUESTAS 9
Responder
Mensaje 1 de 10
944 Vistas, 9 Respuestas
Hi! i keep getting this messege and mi Autocad2019 keeps crashing. Please i need a solutcion, ive tried some online but non seems to work.
Etiquetas (1)
9 RESPUESTAS 9
Mensaje 2 de 10
Alfred.NESWADBA
en respuesta a: Anonymous
When do you get this message?
  • specific dwg-file
  • specific command
Some other questions:
  • Is this a new installation and you had the error since installation?
  • Have you installed all updates
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Mensaje 3 de 10
en respuesta a: Alfred.NESWADBA
Hi @Alfred.NESWADBA ! thanks for answering,
it happend when i run the program, i tried to open a dxf file and it crashed and also trying to open a new dwg file.
Yes, Ive install the updates and no, its not a new installation, ive had this version since last year and ive never had this problem before and i use it regulary.
Mensaje 4 de 10
Alfred.NESWADBA
>> file and it crashed
Does it crash only with this specific file?
Every time you create a new file or just every there and then?
If you can't create new files any more then please change your default template file.
- alfred -
Alfred NESWADBA
Mensaje 5 de 10
Hi @Alfred.NESWADBA
Yes, just with this file apparently, i've tried to use diferent templates and the template i usually use and not open the dxf file and it didn't crashed. I guess this file is just the problem? could it be that? because i´ve tried with other dxf files and didn't have a problem, i don't understand, the only diference is that this file in particular was exported from a gis software.
Thanks!
Mensaje 6 de 10
Alfred.NESWADBA
Yes, if the file has defects it might crash AutoCAD.
Can you upload this file so we can try to reproduce this on our workstations (and hopefully repair the DXF)?
- alfred -
Alfred NESWADBA
Mensaje 7 de 10
hi @Alfred.NESWADBA !
sory for de dely, unfortunately it doesn't let me upload the file, i get this error messege when i try: "The attachment's prueba 2.dxf content type (application/x-dxf) does not match its file extension and has been removed".
thanks for all the help!
Mensaje 8 de 10
Alfred.NESWADBA
>> i get this error messege when i try: [...]
You can ZIP the DXF-file and upload the ZIP-file.
- alfred -
Alfred NESWADBA
Mensaje 9 de 10
Hey @Alfred.NESWADBA ! Here is the zipped-file we've been talking about.
Thanks!
Mensaje 10 de 10
Alfred.NESWADBA
I opened the file with AutoCAD 2022, no crash, all doing well.
There are a lot of points in the drawing, 3 are at 0,0,0 which I removed to make you more happy with ZOOM EXTENTS.
File attached.
- alfred -
Alfred NESWADBA
Publicar en los foros
Administrator Productivity
