Installation & Licensing
cancelar
Mostrando los resultados de
Quiere decir:
Fatal Error: Unhandled e0434352h exception at C6804B59h
3 RESPUESTAS 3
Responder
Mensaje 1 de 4
713 Vistas, 3 Respuestas
Every time I open autocad electrical, I get this error if i load any projects. In order to make the error go away , i have to remove the LastPROJ.FIL file from C:\Users\XXXX\AppData\Roaming\Autodesk\AutoCAD Electrical 2019\R23.0\enu\Support\User. Any idea what causes this error?
Etiquetas (2)
Etiquetas (2)
3 RESPUESTAS 3
Mensaje 2 de 4
rhesusminus
en respuesta a: Anonymous
In addition to lastproj.fil, delete all *.MDB files in the same folder. Does that make any difference?
What version AcadE are you running?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. :cara_guiñando_un_ojo:
Mensaje 3 de 4
Thanks for your reply
It didnt make any difference. I am using ACADE 2019. This process worked the other day but returned back to old state after a restart
Mensaje 4 de 4
rhesusminus
Have you had a look at the contents of the lastproj.fil when it won't start? You should be able to open it with notepad or another text editor.
Trond Hasse Lie
Ctrl Alt El
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
Publicar en los foros
Administrator Productivity
