Installation & Licensing
1 Kudo
11 Solutions
Post 1 of 7
Failure message during installation
271 Views, 6 Replies
02-29-2012 05:27 PM
I have the attached message while trying to install Inventor 2012.  I have Inventor 2011 in the system.  Do I need to remove 2011 in order to install 2012?
Any advise on what is wrong with my installation?
Excellent and it works.  By removing the Microsoft C++ files as being told and re-installed the software.  Thanks.
Community Visitor
Post 2 of 7
Re: Failure message during installation
02-29-2012 08:31 PM in reply to: luiww
I've had the same problem with Autodesk Revit MEP 2012 and one otther one, ive tried a few installs and redownloaded it, nothing worked, did  you get yours working?
3 Kudos
1 Solution
Post 3 of 7
03-01-2012 05:41 AM in reply to: luiww
I was having the same problem and the fix I posted in reply to "Total installati​on failure consistent​ly"  posted by tc8224 worked for me and 2 others. I'm running Windows 7 64 bit so please take that into account.
Search for the "Total installati​on failure consistent​ly"  post & see if that's what you're facing.
AUTODESK EXPERT ELITE
1394 Kudos
849 Solutions
Post 4 of 7
03-01-2012 10:43 AM in reply to: luiww
The problem is detailed in your log file.
It is failing on your C++ 2010 Redistributable.  Delete this program from your Control Panel > Programs and try to install again.
Community Visitor
Post 5 of 7
03-01-2012 02:15 PM in reply to: luiww
It may have to do with the 2012 versions because I went and tried the 2011 and all I tried worked
1394 Kudos
849 Solutions
Post 6 of 7
03-01-2012 02:17 PM in reply to: MATTHEW.GROSSKREUZ
Yes, the 2012 versions typically are showing installation errors when the required prerequisites that are already installed are newer than the installer expects.  Generally uninstalling the prereq fixes this 99% of the time.
Highlighted
1 Kudo
11 Solutions
Post 7 of 7
03-02-2012 04:24 AM in reply to: luiww
Community Alert
The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Community Alert | The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
