Failing to install
Failing to install
houghtob123
Message 1 of 9
Failing to install
houghtob123
I had 3ds max 2018 previously installed but it glitched and wouldn't run. I got rid of it and have been trying to install it again but it constantly fails now. I have already tried using the browser install files. Does anyone know what I can do?
Install log is attached.
Thank you!
Replies (8)
Message 2 of 9
Mark.Lancaster
@houghtob123
Welcome to the Autodesk User's Community..
As far as I know the 1632 error that's in your installation log file indicates the temp folder is full..  I would recommend that you clean out C:\Temp, C:\Windows\Temp and your personal temp (%temp%).
Good luck and report back on your progress.
Mark Lancaster
Message 3 of 9
dembkod
houghtob123
Hello. Cleaning out the temp files is a great place to start. If you are getting any errors on screen, that’s a good place to start research too. Before installing, I would also uninstall the Microsoft C++ redistributables from your machine. They are dependencies that our programs try to install. If they are already present, they may conflict with the installation.
Hope it helps!
David Dembkoski
Message 4 of 9
natasha.l
Hello @houghtob123,
Welcome.
You should also consider uninstalling any remaining files from your old installation, then try to download & install using another method.
  1. Conduct a Clean Uninstall of the application & use the MSfixitTool to complete it
  2. Reboot the computer & log in as Administrator
  3. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  4. Use the Browser Download Method in your Autodesk Account or via the AVA | Autodesk Virtual Agent (download all the parts)
Let us know how it turns out.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 5 of 9
natasha.l
Hello @houghtob123,
I wanted to check-in with you, I hope you were able to resolve the issue with your  3ds Max software.
Message 6 of 9
houghtob123
Unfortunately my temp directories have been cleaned (they weren't very full in the first place) and the issue persists. I am currently trying some of the other suggestions to see if they help.
Thanks for the reply and help.
Message 7 of 9
houghtob123
Hello dembkod,
Unfortunately the redistributables were not the issue. Installation fails after uninstalling the programs and removing any leftovers with revo. I am now trying other suggestions posed to see if they help.
Thanks for the help!
Message 8 of 9
houghtob123
Hello natashal84,
I have tried your suggestion and it seems to have allowed the installer to at least attempt to install something before it fails. It now fails at trying to install the c++ 2010 sp1 redistributable(x86), at least according to the log file and me watching it. The installer tells me that 3ds Max 201, Arnold renderer, and the desktop app failed. I'm thinking I may need to do a fresh install of windows to get this working...
Here is a copy of the log:
2018/1/26:20:03:00    houghtob123    DESKTOP-3IJ1HH6    === Setup started on DESKTOP-3IJ1HH6 by houghtob123 ===
2018/1/26:20:03:00    houghtob123    DESKTOP-3IJ1HH6    Launch
2018/1/26:20:03:00    houghtob123    DESKTOP-3IJ1HH6    CommandLine
2018/1/26:20:03:06    houghtob123    DESKTOP-3IJ1HH6    === Setup ended ===
2018/1/26:20:03:01    houghtob123    DESKTOP-3IJ1HH6    === Setup started on DESKTOP-3IJ1HH6 by houghtob123 ===
2018/1/26:20:03:01    houghtob123    DESKTOP-3IJ1HH6    Launch
2018/1/26:20:03:06    houghtob123    DESKTOP-3IJ1HH6    PageOpen    LaunchDialog
2018/1/26:20:03:42    houghtob123    DESKTOP-3IJ1HH6    PageOpen    LicenseDialog
2018/1/26:20:03:43    houghtob123    DESKTOP-3IJ1HH6    PageOpen    ProductInfoDialog
2018/1/26:20:03:43    houghtob123    DESKTOP-3IJ1HH6    PageOpen    ProductSelectionDialog2
2018/1/26:20:03:58    houghtob123    DESKTOP-3IJ1HH6    PageOpen    FullProgressDialog
2018/1/26:20:03:58    houghtob123    DESKTOP-3IJ1HH6    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "D:\Autodesk\Autodesk_3ds_Max_2018_EFGJKPS_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2018/1/26:20:04:00    houghtob123    DESKTOP-3IJ1HH6    Microsoft Visual C++ 2010 SP1 Redistributable (x86) return code: 1632
2018/1/26:20:04:00    houghtob123    DESKTOP-3IJ1HH6    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
Thanks for the help! I will try the web installer now.
Message 9 of 9
houghtob123
So I got it working. After trying all suggestions and a few things myself only a clean installation of windows worked.
I don't know what happened but it wasn't the 3DS Max installer.
Thanks for the help guys.
