I cant seem to download autocad cival 3d 2014 for school what should I do? Attached is a screen shot of the error.
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Welcome to the community..
When sharing information please make sure images do not contain personal information such as your serial #. I will have the moderator remove it to protect your educational serial #.
Now to your problem...
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
& Autodesk Services MarketPlace Provider
My computer was not powerful enough to run autocad. Your solution worked great after I bought a new computer. Thank you!!!
