Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
FabEST MEP (Single User) License File Location?
1 RESPUESTA 1
Responder
Mensaje 1 de 2
662 Vistas, 1 Respuesta
Hello!
I am trying to assist one of our end users with installing the 2019 version of FabEST MEP (who needs it to load the ITMs so she can then use 2021). I was told the license file for 2021 would also work for the 2019 version - however, I can't locate the license file she needs to activate it. Anyone know the path?
Etiquetas (1)
1 RESPUESTA 1
Mensaje 2 de 2
dyoung
en respuesta a: Anonymous
Should just need to be logged in with their Autodesk ID. If you weren't a licensed user of 2019 when 2019 was out, I don't think a license of 2021 will let use use it. Prior version access (as far as I know) only works if you were a subscriber or on a maintenance subscription when 2019 was released.
There's not really a "File" to use. If an Autodesk ID doesn't work, you an try activating using the serial number which can be accessed via the Autodesk Accounts portal by your contract manager or secondary admin.
Darren J. Young
http://www.darrenjyoung.com/
https://www.linkedin.com/in/darrenjyoung/
Publicar en los foros
Administrator Productivity
