I am able to bring spreadsheets into my DWG using the special paste feature. I sometimes need to, and can't figure out how to rotate the spread sheet 90 deg. Is there a way of rotating the spreadsheet once I "Special Paste' it?
Ashton
This forum is about installation and licensing of Autodesk Application and not for asking questions about workflows in a given application. I assume you are referring to AutoCAD drawings or perhaps you are using another Autodesk Application (but I can only speculate at this point).
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @ashton995,
If you are referring to AutoCAD you can actually import the Excel data by xrefing it in this will keep you from having to constantly having to copy/pasting the updated data.
Check this How To Link Data in a Data Extraction Table to a Spreadsheet article .
To copy/paste make sure your UC(X&Y) is set properly, then "Rotate" with "Ortho" on.
Keep us posted.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @ashton995,
Please let us know if you have figured out the Excel integration in your dwg.
Natasha
Helpful Links:
