Error when installing inventor 2024 - Error 82
htthanh_dzk
Message 1 of 29
htthanh_dzk
z4322704442880_55b7678a74a99f63519c57a2d93444b5.jpgAfter installing Inventor 2024, the program won’t launch with the following error ‘Failed to initialize a component for accessing AutoCAD files. Please try again. Error 82.’
Help me!
Replies (28)
Message 21 of 29
teldiocalbe
Community Visitor
Community Visitor
It worked. This really is the solution to the problem
Message 22 of 29
AutodeskCommunityUser
Thank you that was very usefull,
Common Autodesk fix your installation software.
I installed process monitor to find what file is missing - see screenshots.
and indeed My Inventor 2025 gave me those error after installation:
Failed to initialize a component for aqccessing AutoCAD files.
Please try again.
Error 16
What was needed was to manually create file:
c:\Users\kleme\AppData\Roaming\Autodesk\Inventor 2025\RealDWGSettings.xml
And add this content to it:
<?xml version="1.0" encoding="utf-16" standalone="no" ?>
<RealDWGSettings InstallDirectory="C:\Program Files\Common Files\Autodesk Shared\RealDWG Shared 2025"></RealDWGSettings>
Message 23 of 29
gamissamir
Community Visitor
Community Visitor
wow! i open the notepad, copy paste your code, save code in .xml and put in the file on location, and then i opened the software, IT WORKS! i struggled to figure out this problem for a day. good solution, man! liked 👍
Message 24 of 29
kelvin240390
Community Visitor
Community Visitor
No way! thank you so much bro.
Message 25 of 29
fathomath27
Community Visitor
Community Visitor
i love you 4ever broooooooooooo
Message 26 of 29
jameslabelle01
Community Visitor
Community Visitor
It worked for me too!  I was installing Inventor 2025 and had to adjust the code to read 2025.  way better than a clean uninstall that Autodesk suggested.  THanks!
Message 27 of 29
weirdoffx
Community Visitor
Community Visitor
can i know the adjustment please ?
Message 28 of 29
rachmat_dzanzani
Community Visitor
Community Visitor
THANK YOU SM
Message 29 of 29
memde
Thanks for the fix. I had this issue after installing Inventor 2026. Two years later, and interesting that this issue hasn't been corrected in the installer.
