Error when installing inventor 2024 - Error 82
htthanh_dzk
Message 1 of 29
htthanh_dzk
z4322704442880_55b7678a74a99f63519c57a2d93444b5.jpgAfter installing Inventor 2024, the program won’t launch with the following error ‘Failed to initialize a component for accessing AutoCAD files. Please try again. Error 82.’
Help me!
Replies (28)
Message 2 of 29
Gabriel_Watson
Unfortunately, the fix seems to be a thorough uninstall and then reinstall:
https://resources.imaginit.com/support-blog/inventor-2024-failed-to-initialize-a-component-for-acces...
Message 3 of 29
serajr
Did you manage to get it working? We' re facing the same problem here.
Is @Gabriel_Watson's "solution" the only one that works?
Thanks in advance!
Message 4 of 29
co_lam
No, Gabriel_Watson's solution is not suitable. This problem is related to the copyright license of the software. So you need to check if the Autodesk desktop licensing service is working properly.
Message 5 of 29
serajr
Thanks for the info.
It's kinda weird, but the mentioned service is working (up and running), I'm based on these instructions from Adsk:
https://tinyurl.com/34utyh27
Message 6 of 29
long0212le
am i also getting this error? Has anyone found a solution yet?
Message 7 of 29
VTwins1968
Message 8 of 29
technical.eng1
Community Visitor
Community Visitor
Hello.
Please guide me to fix this error
Message 9 of 29
0279137
Community Visitor
Community Visitor
same here, do I need to purchase autocad?
Message 10 of 29
henkstubbe
I had the same problem. It turned out to be a missing file in the user profile.
"c:\Users\%userprofile%\AppData\Roaming\Autodesk\Inventor 2024\RealDWGSettings.xml" needs to exist and at least contain the installation location of realdwg.
<?xml version="1.0" encoding="utf-16" standalone="no" ?>
<RealDWGSettings InstallDirectory="C:\Program Files\Common Files\Autodesk Shared\RealDWG Shared 2024"></RealDWGSettings>
Why this POS doesn't just use the standard value in case it's missing, or ask the registry... But noooo, of course not.
Message 11 of 29
23chaos23
You bloody legend, this fixed the problem.
open notepad, paste the doobly doo, save as the missing .xml and paste it in the place. BOOM working software.
Message 12 of 29
OptimalConsulting
Community Visitor
Community Visitor
the message disappeared but inventor crashes after launch.
Message 13 of 29
hasaner07
You are great
Message 14 of 29
alkaser_27
you are genius.
thank you...
Message 15 of 29
eotamis
Observer
Observer
Having issues with my setup..
To clarify, do you just need an empty xml file with the said specific name or actually realDWG installed on the system?
thanks
Message 16 of 29
eotamis
Observer
Observer
please disregard the post, fixed it. I could have not imagined the days have finally come for us fellow users patching defected products..
Message 17 of 29
abt102
A customer of us had the same problem, but in this case the whole directory was empty!
A copy of the files + folders from a working workstation solved the problem.
Message 18 of 29
ArshjeetSingh21
Community Visitor
Community Visitor
Thanks Bro 🙂
Message 19 of 29
askhamis55555
Observer
Observer
thanks alot it worked like charm,
the steps :
1.create a new notepad.
2.copy and paste these two lines of code in it "
3.save the notepade and rename it with "RealDWGSettings.xml"
4.place the notepad in this location inside this folder ""c:\Users\%userprofile%\AppData\Roaming\Autodesk\Inventor 2024"
5.open the application and it worked.
Message 20 of 29
redilamaj15
Community Visitor
Community Visitor
May God give life to you and your family for your explanation!
