Hi guys!
Well, im trying to install for a week 3ds max and is not working at all.
I need it for the university and times is against me.
I found through this forum so many solutions and no one is working.
I tried to fix it by uninstalling Microsoft C++ .... But not working
I tried to fix setup.ini on notepad changing the lines and deleting..... not working.
I tried with ORCA and... not working.
I dont know what else I can do.
And ofcourse I run it by administrator, No firewalls and no antivirus.
This is the loginfo if someone can help me.
Thanks!
Solved by ukdxb012. Go to Solution.
Hi Maneleki, Welcome to the forums.
The issue could be related to the path of the installation files. Move the installation files from your D drive onto your C drive. Afterwards, shorten the folder name.
D:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
To:
C:\Autodesk\3DSMAX
Before attempting to reinstall, first clear out your temp directory C:\Users\<username>\Appdata\Local\Temp
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
I try all you said and didnt work, here is the log info:
2015/3/26:01:25:46 Collapse COLLAPSE-PC === Setup started on COLLAPSE-PC by Collapse ===
2015/3/26:01:25:46 Collapse COLLAPSE-PC Path_Length: 148
2015/3/26:01:25:46 Collapse COLLAPSE-PC Current Directory C:\Autodesk
2015/3/26:01:25:46 Collapse COLLAPSE-PC Launch
2015/3/26:01:25:46 Collapse COLLAPSE-PC CommandLine
2015/3/26:01:25:46 Collapse COLLAPSE-PC Current Directory C:\Users\Collapse\AppData\Local\Temp\_AIFF86.tmp
2015/3/26:01:25:53 Collapse COLLAPSE-PC === Setup ended ===
2015/3/26:01:25:48 Collapse COLLAPSE-PC === Setup started on COLLAPSE-PC by Collapse ===
2015/3/26:01:25:48 Collapse COLLAPSE-PC Path_Length: 148
2015/3/26:01:25:48 Collapse COLLAPSE-PC Current Directory C:\Users\Collapse\AppData\Local\Temp\_AIFF86.tmp
2015/3/26:01:25:48 Collapse COLLAPSE-PC Launch
2015/3/26:01:25:51 Collapse COLLAPSE-PC PageOpen LaunchDialog
2015/3/26:01:26:56 Collapse COLLAPSE-PC PageOpen LicenseDialog
2015/3/26:01:26:58 Collapse COLLAPSE-PC PageOpen ProductInfoDialog
2015/3/26:01:28:01 Collapse COLLAPSE-PC PageOpen ProductSelectionDialog2
2015/3/26:01:28:17 Collapse COLLAPSE-PC PageOpen FullProgressDialog
2015/3/26:01:28:18 Collapse COLLAPSE-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2015/3/26:01:29:18 Collapse COLLAPSE-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/3/26:01:29:19 Collapse COLLAPSE-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2015/3/26:01:29:31 Collapse COLLAPSE-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/3/26:01:29:31 Collapse COLLAPSE-PC Installing DirectX® Runtime: "C:\Autodesk\3rdParty\DirectX\DXSETUP.exe" /silent
2015/3/26:01:29:50 Collapse COLLAPSE-PC Install DirectX® Runtime Succeeded
2015/3/26:01:29:50 Collapse COLLAPSE-PC Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/3/26:01:30:20 Collapse COLLAPSE-PC Install Autodesk® Material Library 2015 Succeeded
2015/3/26:01:30:20 Collapse COLLAPSE-PC Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/3/26:01:30:37 Collapse COLLAPSE-PC Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2015/3/26:01:30:37 Collapse COLLAPSE-PC Installing Autodesk® Material Library 2015 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/3/26:01:31:21 Collapse COLLAPSE-PC Install Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2015/3/26:01:31:25 Collapse COLLAPSE-PC Installing Autodesk® 3ds Max 2015: TRANSFORMS="C:\Users\Collapse\AppData\Local\Temp\_AIFF86.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\" INSTALLDIR="C:\Program Files\Autodesk\3dsMax\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/3/26:01:33:04 Collapse COLLAPSE-PC Install Autodesk® 3ds Max 2015 Failed Installation aborted, Result=1603
2015/3/26:01:33:45 Collapse COLLAPSE-PC Rollback Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2015/3/26:01:34:17 Collapse COLLAPSE-PC Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2015/3/26:01:35:07 Collapse COLLAPSE-PC Rollback Autodesk® Material Library 2015 Succeeded
2015/3/26:01:35:07 Collapse COLLAPSE-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/3/26:01:35:07 Collapse COLLAPSE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2015/3/26:01:35:07 Collapse COLLAPSE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
thanks!
I copied this from a fellow EE member, check out the original post here... http://forums.autodesk.com/t5/installation-licensing/how-to-determine-errors-in-installation-log-fil...
Possible Reasons: The failure is not evident in this log file. You may have to open your %TEMP% location again and locate the specific log file for the product that is failing. Common failures may include failures to install while adding a service pack to the installation, similar vertical product is already installed, permissions issues, or malware infections.
It is always recommended that you install with:
- Local Administrator Rights (Not to be confused with Doman Admin Rights)
- UAC (User Account Control) turned off in Windows. See this video for more information.
- Antivirus temporarily disabled.
- Installation files on the local hard drive rather from disc or removable media.
- Installation in default location and not using Roaming Profiles.
For more information on how to resolve this issue when service packs are included or vertical products already exist, please see my KB article here:
OK, now i found the two loginfo that could be possible on the
TEMP folder.
I could only upload the setuplog, coz is so heavy files. But on the other one, it exists this, as last text:
Property(S): REBOOT = ReallySuppress
Property(S): ADSK_SETUP_EXE = 1
Property(S): CURRENTDIRECTORY = C:\Users\Collapse\AppData\Local\Temp\_AIACC5.tmp\Setup
Property(S): CLIENTUILEVEL = 3
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTPROCESSID = 2516
Property(S): MsiSystemRebootPending = 1
Property(S): VersionDatabase = 405
Property(S): VersionMsi = 5.00
Property(S): VersionNT64 = 601
Property(S): WindowsBuild = 7600
Property(S): ServicePackLevel = 0
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): System64Folder = C:\Windows\system32\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): RemoteAdminTS = 1
Property(S): FavoritesFolder = C:\Users\Collapse\Favorites\
Property(S): NetHoodFolder = C:\Users\Collapse\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): PrintHoodFolder = C:\Users\Collapse\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): RecentFolder = C:\Users\Collapse\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): SendToFolder = C:\Users\Collapse\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): LocalAppDataFolder = C:\Users\Collapse\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Collapse\Pictures\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): MsiAMD64 = 6
Property(S): Msix64 = 6
Property(S): Intel = 6
Property(S): PhysicalMemory = 16268
Property(S): VirtualMemory = 27135
Property(S): AdminUser = 1
Property(S): MsiTrueAdminUser = 1
Property(S): LogonUser = Collapse
Property(S): UserSID = S-1-5-21-3886683878-1358582564-2712474434-1000
Property(S): UserLanguageID = 3082
Property(S): ComputerName = COLLAPSE-PC
Property(S): SystemLanguageID = 3082
Property(S): ScreenX = 1024
Property(S): ScreenY = 768
Property(S): CaptionHeight = 22
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): TextInternalLeading = 3
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 1:50:10
Property(S): MsiNetAssemblySupport = 4.0.30319.17929
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): RedirectedDllSupport = 2
Property(S): MsiRunningElevated = 1
Property(S): Privileged = 1
Property(S): USERNAME = Collapse
Property(S): DATABASE = C:\Windows\Installer\a6c7f2.msi
Property(S): OriginalDatabase = C:\Autodesk\x64\max\3dsMax.msi
Property(S): UILevel = 2
Property(S): MsiUISourceResOnly = 1
Property(S): ACTION = INSTALL
Property(S): ROOTDRIVE = D:\
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): SOURCEDIR = C:\Autodesk\x64\max\
Property(S): SourcedirProduct = {52B37EC7-D836-0410-0264-3C24BCED2010}
Property(S): MR_PORT_OK = 1
MSI (s) (94:B0) [01:50:10:535]: Note: 1: 1708
MSI (s) (94:B0) [01:50:10:535]: Note: 1: 2205 2: 3: Error
MSI (s) (94:B0) [01:50:10:535]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1708
MSI (s) (94:B0) [01:50:10:535]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (94:B0) [01:50:10:536]: Product: Autodesk 3ds Max 2015 -- Installation failed.
MSI (s) (94:B0) [01:50:10:538]: Windows Installer installed the product. Product Name: Autodesk 3ds Max 2015. Product Version: 17.0.630.0. Product Language: 1033. Manufacturer: Autodesk. Installation success or error status: 1603.
MSI (s) (94:B0) [01:50:10:555]: Attempting to delete file C:\Windows\Installer\a6c7f3.mst
MSI (s) (94:B0) [01:50:10:556]: Unable to delete the file. LastError = 32
MSI (s) (94:B0) [01:50:10:590]: Deferring clean up of packages/files, if any exist
MSI (s) (94:B0) [01:50:10:591]: Attempting to delete file C:\Windows\Installer\a6c7f3.mst
MSI (s) (94:B0) [01:50:10:592]: MainEngineThread is returning 1603
MSI (s) (94:40) [01:50:10:592]: No System Restore sequence number for this installation.
=== Logging stopped: 26/03/2015 1:50:10 ===
MSI (s) (94:40) [01:50:10:595]: User policy value 'DisableRollback' is 0
MSI (s) (94:40) [01:50:10:595]: Machine policy value 'DisableRollback' is 0
MSI (s) (94:40) [01:50:10:595]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (94:40) [01:50:10:595]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (94:40) [01:50:10:597]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (94:40) [01:50:10:601]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (94:40) [01:50:10:601]: Restoring environment variables
MSI (s) (94:40) [01:50:10:603]: Destroying RemoteAPI object.
MSI (s) (94:98) [01:50:10:603]: Custom Action Manager thread ending.
MSI (c) (D4:6C) [01:50:10:606]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (D4:6C) [01:50:10:608]: MainEngineThread is returning 1603
=== Verbose logging stopped: 26/03/2015 1:50:10 ===
Can someone help me?
thanks.
This is the issue... 2015/3/26:01:50:10 Collapse COLLAPSE-PC Install Autodesk® 3ds Max 2015 Failed Installation aborted, Result=1603
Please go back to my previous response and check everything on the list.
P.S - How did you download the installer in the 1st place? http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
If it was "Download Now" or "Install Now", this could be the root of the issue. I would suggest redownloading as "Browser Download" from your Autodesk Account Login or the Autodesk Virtual Agent... http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Hello Duncan,
I've already checked your list in the post you refered but still getting the installation crashed. Although it reports error #1603 it might be because of Directx. This is the first item to fail in the installation. Next the three last lines of the log "3dsMax_2015_Setup".
2015/3/27:17:01:32 Collapse COLLAPSE-PC Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2015/3/27:17:02:35 Collapse COLLAPSE-PC Rollback Autodesk® Material Library 2015 Succeeded
2015/3/27:17:02:35 Collapse COLLAPSE-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/3/27:17:02:36 Collapse COLLAPSE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2015/3/27:17:02:36 Collapse COLLAPSE-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
I have admin rights and also UAC disabled.
I hope you can help me.
Thank you
i think i have the same problem , any help?
2018/4/20:21:29:05 Fawzia Eha LENOVO-PC === Setup started on LENOVO-PC by Fawzia Ehab ===
2018/4/20:21:29:05 Fawbzia Ehab LENOVO-PC Path_Length: 157
2018/4/20:21:29:05 Fawzia Ehab LENOVO-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US
2018/4/20:21:29:05 Fawzia Ehab LENOVO-PC Launch
2018/4/20:21:29:05 Fawzia Ehab LENOVO-PC CommandLine /PK 128I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en..."
2018/4/20:21:29:05 Fawzia Ehab LENOVO-PC Setup Windows update reboot is pending
2018/4/20:21:29:19 Fawzia Ehab LENOVO-PC Setup Autodesk 3ds Max 2017 Will restart automatically.
2018/4/20:21:29:19 Fawzia Ehab LENOVO-PC === Setup ended ===
2018/4/20:21:43:24 Fawzia Ehab LENOVO-PC === Setup started on LENOVO-PC by Fawzia Ehab ===
2018/4/20:21:43:24 Fawzia Ehab LENOVO-PC Path_Length: 157
2018/4/20:21:43:24 Fawzia Ehab LENOVO-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US
2018/4/20:21:43:24 Fawzia Ehab LENOVO-PC Launch
2018/4/20:21:43:24 Fawzia Ehab LENOVO-PC CommandLine /PK 128I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en..."
2018/4/20:21:43:24 Fawzia Ehab LENOVO-PC Current Directory C:\Users\FAWZIA~1\AppData\Local\Temp\_AIFE8.tmp
2018/4/20:22:13:06 Fawzia Ehab LENOVO-PC === Setup ended ===
2018/4/20:21:43:27 Fawzia Ehab LENOVO-PC === Setup started on LENOVO-PC by Fawzia Ehab ===
2018/4/20:21:43:27 Fawzia Ehab LENOVO-PC Path_Length: 157
2018/4/20:21:43:27 Fawzia Ehab LENOVO-PC Current Directory C:\Users\FAWZIA~1\AppData\Local\Temp\_AIFE8.tmp
2018/4/20:21:43:27 Fawzia Ehab LENOVO-PC Launch
2018/4/20:21:50:01 Fawzia Ehab LENOVO-PC Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPM...
2018/4/20:21:50:10 Fawzia Ehab LENOVO-PC Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPM...
2018/4/20:21:50:15 Fawzia Ehab LENOVO-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_...
2018/4/20:22:13:06 Fawzia Ehab LENOVO-PC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_...
2018/4/20:22:13:06 Fawzia Ehab LENOVO-PC PageOpen LaunchDialog
2018/4/20:22:14:20 Fawzia Ehab LENOVO-PC PageOpen LicenseDialog
2018/4/20:22:14:20 Fawzia Ehab LENOVO-PC PageOpen ProductInfoDialog
2018/4/20:22:14:21 Fawzia Ehab LENOVO-PC PageOpen ProductSelectionDialog2
2018/4/20:22:14:41 Fawzia Ehab LENOVO-PC PageOpen FullProgressDialog
2018/4/20:22:14:42 Fawzia Ehab LENOVO-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTM...
2018/4/20:22:14:45 Fawzia Ehab LENOVO-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTM...
2018/4/20:22:14:46 Fawzia Ehab LENOVO-PC Download Play VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/20:22:16:30 Fawzia Ehab LENOVO-PC Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/20:22:16:30 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2018/4/20:22:16:33 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2018/4/20:22:16:37 Fawzia Ehab LENOVO-PC Download Play VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/20:22:18:10 Fawzia Ehab LENOVO-PC Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/20:22:18:10 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2018/4/20:22:18:10 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2018/4/20:22:18:14 Fawzia Ehab LENOVO-PC Download Play VCREDIST2013X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/20:22:19:24 Fawzia Ehab LENOVO-PC Download Complete VCREDIST2013X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/20:22:19:24 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\FAWZIA~1\AppData\Local\Temp\vcredist_x86_2013.log
2018/4/20:22:19:25 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded
2018/4/20:22:19:25 Fawzia Ehab LENOVO-PC Download Play VCREDIST2013X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/20:22:20:42 Fawzia Ehab LENOVO-PC Download Complete VCREDIST2013X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/20:22:20:42 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\FAWZIA~1\AppData\Local\Temp\vcredist_x64_2013.log
2018/4/20:22:20:43 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded
2018/4/20:22:20:45 Fawzia Ehab LENOVO-PC Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CM.tar...
2018/4/20:23:08:29 Fawzia Ehab LENOVO-PC Download Complete CM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CM.tar...
2018/4/20:23:08:29 Fawzia Ehab LENOVO-PC Installing Autodesk® Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/4/20:23:08:56 Fawzia Ehab LENOVO-PC Install Autodesk® Material Library 2017 Succeeded
2018/4/20:23:09:00 Fawzia Ehab LENOVO-PC Download Play CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILB....
2018/4/20:23:20:39 Fawzia Ehab LENOVO-PC Download Complete CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILB....
2018/4/20:23:20:39 Fawzia Ehab LENOVO-PC Installing Autodesk® Material Library 2017 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/4/20:23:21:17 Fawzia Ehab LENOVO-PC Install Autodesk® Material Library 2017 - Base Image Library Succeeded
2018/4/20:23:21:22 Fawzia Ehab LENOVO-PC Download Play CMILM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:00:27:50 Fawzia Ehab LENOVO-PC Download Error CMILM <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:00:27:51 Fawzia Ehab LENOVO-PC Download Error CMILM Decompressing failed http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:00:27:51 Fawzia Ehab LENOVO-PC Download Aborted CMILM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:00:27:51 Fawzia Ehab LENOVO-PC Install Autodesk® Material Library 2017 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2018/4/21:00:27:53 Fawzia Ehab LENOVO-PC Rollback Autodesk® Material Library 2017 - Base Image Library Succeeded
2018/4/21:00:28:09 Fawzia Ehab LENOVO-PC Rollback Autodesk® Material Library 2017 Succeeded
2018/4/21:00:28:09 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
2018/4/21:00:28:09 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
2018/4/21:00:28:09 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2018/4/21:00:28:09 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2018/4/21:00:28:10 Fawzia Ehab LENOVO-PC PageOpen InstallCompleteDialog
2018/4/21:00:37:34 Fawzia Ehab LENOVO-PC === Setup ended ===
2018/4/21:00:44:02 Fawzia Ehab LENOVO-PC === Setup started on LENOVO-PC by Fawzia Ehab ===
2018/4/21:00:44:02 Fawzia Ehab LENOVO-PC Path_Length: 157
2018/4/21:00:44:02 Fawzia Ehab LENOVO-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US
2018/4/21:00:44:02 Fawzia Ehab LENOVO-PC Launch
2018/4/21:00:44:02 Fawzia Ehab LENOVO-PC CommandLine /PK 128I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en..."
2018/4/21:00:44:02 Fawzia Ehab LENOVO-PC Current Directory C:\Users\FAWZIA~1\AppData\Local\Temp\_AI70B3.tmp
2018/4/21:00:44:05 Fawzia Ehab LENOVO-PC === Setup ended ===
2018/4/21:00:44:03 Fawzia Ehab LENOVO-PC === Setup started on LENOVO-PC by Fawzia Ehab ===
2018/4/21:00:44:03 Fawzia Ehab LENOVO-PC Path_Length: 157
2018/4/21:00:44:03 Fawzia Ehab LENOVO-PC Current Directory C:\Users\FAWZIA~1\AppData\Local\Temp\_AI70B3.tmp
2018/4/21:00:44:03 Fawzia Ehab LENOVO-PC Launch
2018/4/21:00:44:04 Fawzia Ehab LENOVO-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPM...
2018/4/21:00:44:05 Fawzia Ehab LENOVO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_...
2018/4/21:00:44:05 Fawzia Ehab LENOVO-PC PageOpen LaunchDialog
2018/4/21:00:44:14 Fawzia Ehab LENOVO-PC PageOpen LicenseDialog
2018/4/21:00:44:14 Fawzia Ehab LENOVO-PC PageOpen ProductInfoDialog
2018/4/21:00:44:14 Fawzia Ehab LENOVO-PC PageOpen ProductSelectionDialog2
2018/4/21:00:45:42 Fawzia Ehab LENOVO-PC PageOpen FullProgressDialog
2018/4/21:00:45:54 Fawzia Ehab LENOVO-PC Download Error Connection has expired. Please reconnect to site. STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en...
2018/4/21:00:46:03 Fawzia Ehab LENOVO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/21:00:46:03 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2018/4/21:00:46:04 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2018/4/21:00:46:04 Fawzia Ehab LENOVO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/21:00:46:04 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2018/4/21:00:46:05 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2018/4/21:00:46:05 Fawzia Ehab LENOVO-PC Download Skipped VCREDIST2013X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/21:00:46:05 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\FAWZIA~1\AppData\Local\Temp\vcredist_x86_2013.log
2018/4/21:00:46:05 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded
2018/4/21:00:46:05 Fawzia Ehab LENOVO-PC Download Skipped VCREDIST2013X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/21:00:46:05 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\FAWZIA~1\AppData\Local\Temp\vcredist_x64_2013.log
2018/4/21:00:46:06 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded
2018/4/21:00:46:06 Fawzia Ehab LENOVO-PC Download Skipped CM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CM.tar...
2018/4/21:00:46:06 Fawzia Ehab LENOVO-PC Installing Autodesk® Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/4/21:00:46:23 Fawzia Ehab LENOVO-PC Install Autodesk® Material Library 2017 Succeeded
2018/4/21:00:46:23 Fawzia Ehab LENOVO-PC Download Skipped CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILB....
2018/4/21:00:46:23 Fawzia Ehab LENOVO-PC Installing Autodesk® Material Library 2017 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/4/21:00:46:33 Fawzia Ehab LENOVO-PC Install Autodesk® Material Library 2017 - Base Image Library Succeeded
2018/4/21:00:46:38 Fawzia Ehab LENOVO-PC Download Play CMILM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:01:17:21 Fawzia Ehab LENOVO-PC Download Error CMILM <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:01:17:21 Fawzia Ehab LENOVO-PC Download Error CMILM Decompressing failed http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:01:17:21 Fawzia Ehab LENOVO-PC Download Aborted CMILM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:01:17:21 Fawzia Ehab LENOVO-PC Install Autodesk® Material Library 2017 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2018/4/21:01:17:24 Fawzia Ehab LENOVO-PC Rollback Autodesk® Material Library 2017 - Base Image Library Succeeded
2018/4/21:01:17:39 Fawzia Ehab LENOVO-PC Rollback Autodesk® Material Library 2017 Succeeded
2018/4/21:01:17:39 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
2018/4/21:01:17:39 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
2018/4/21:01:17:39 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2018/4/21:01:17:40 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2018/4/21:01:17:40 Fawzia Ehab LENOVO-PC PageOpen InstallCompleteDialog
2018/4/21:01:18:14 Fawzia Ehab LENOVO-PC === Setup ended ===
2018/4/21:02:34:29 Fawzia Ehab LENOVO-PC === Setup started on LENOVO-PC by Fawzia Ehab ===
2018/4/21:02:34:29 Fawzia Ehab LENOVO-PC Path_Length: 157
2018/4/21:02:34:29 Fawzia Ehab LENOVO-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en-US
2018/4/21:02:34:29 Fawzia Ehab LENOVO-PC Launch
2018/4/21:02:34:29 Fawzia Ehab LENOVO-PC CommandLine /PK 128I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/Autodesk_3ds_Max_2017_EFGJKPS_Win_64bit_wi_en..."
2018/4/21:02:34:29 Fawzia Ehab LENOVO-PC Current Directory C:\Users\FAWZIA~1\AppData\Local\Temp\_AI92C6.tmp
2018/4/21:02:34:42 Fawzia Ehab LENOVO-PC === Setup ended ===
2018/4/21:02:34:33 Fawzia Ehab LENOVO-PC === Setup started on LENOVO-PC by Fawzia Ehab ===
2018/4/21:02:34:33 Fawzia Ehab LENOVO-PC Path_Length: 157
2018/4/21:02:34:33 Fawzia Ehab LENOVO-PC Current Directory C:\Users\FAWZIA~1\AppData\Local\Temp\_AI92C6.tmp
2018/4/21:02:34:33 Fawzia Ehab LENOVO-PC Launch
2018/4/21:02:34:42 Fawzia Ehab LENOVO-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUPM...
2018/4/21:02:34:42 Fawzia Ehab LENOVO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/SETUP_...
2018/4/21:02:34:42 Fawzia Ehab LENOVO-PC PageOpen LaunchDialog
2018/4/21:02:35:00 Fawzia Ehab LENOVO-PC PageOpen LicenseDialog
2018/4/21:02:35:00 Fawzia Ehab LENOVO-PC PageOpen ProductInfoDialog
2018/4/21:02:35:00 Fawzia Ehab LENOVO-PC PageOpen ProductSelectionDialog2
2018/4/21:02:36:15 Fawzia Ehab LENOVO-PC PageOpen FullProgressDialog
2018/4/21:02:36:19 Fawzia Ehab LENOVO-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTM...
2018/4/21:02:36:42 Fawzia Ehab LENOVO-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/STARTM...
2018/4/21:02:36:52 Fawzia Ehab LENOVO-PC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/21:02:36:52 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2018/4/21:02:36:52 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2018/4/21:02:36:53 Fawzia Ehab LENOVO-PC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/21:02:36:53 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2018/4/21:02:36:53 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2018/4/21:02:36:53 Fawzia Ehab LENOVO-PC Download Skipped VCREDIST2013X86 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/21:02:36:53 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\FAWZIA~1\AppData\Local\Temp\vcredist_x86_2013.log
2018/4/21:02:36:54 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded
2018/4/21:02:36:54 Fawzia Ehab LENOVO-PC Download Skipped VCREDIST2013X64 http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/VCREDI...
2018/4/21:02:36:54 Fawzia Ehab LENOVO-PC Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2017\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\FAWZIA~1\AppData\Local\Temp\vcredist_x64_2013.log
2018/4/21:02:36:55 Fawzia Ehab LENOVO-PC Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded
2018/4/21:02:36:55 Fawzia Ehab LENOVO-PC Download Skipped CM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CM.tar...
2018/4/21:02:36:55 Fawzia Ehab LENOVO-PC Installing Autodesk® Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/4/21:02:37:34 Fawzia Ehab LENOVO-PC Install Autodesk® Material Library 2017 Succeeded
2018/4/21:02:37:34 Fawzia Ehab LENOVO-PC Download Skipped CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILB....
2018/4/21:02:37:34 Fawzia Ehab LENOVO-PC Installing Autodesk® Material Library 2017 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2017" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0664-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={66E9D963-1A7E-4E18-884F-8F66BCE51125} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/4/21:02:37:55 Fawzia Ehab LENOVO-PC Install Autodesk® Material Library 2017 - Base Image Library Succeeded
2018/4/21:02:37:56 Fawzia Ehab LENOVO-PC Download Play CMILM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:03:17:52 Fawzia Ehab LENOVO-PC Download Error CMILM <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:03:17:52 Fawzia Ehab LENOVO-PC Download Aborted CMILM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:03:17:52 Fawzia Ehab LENOVO-PC Install Autodesk® Material Library 2017 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2018/4/21:03:17:56 Fawzia Ehab LENOVO-PC Rollback Autodesk® Material Library 2017 - Base Image Library Succeeded
2018/4/21:03:18:21 Fawzia Ehab LENOVO-PC Rollback Autodesk® Material Library 2017 Succeeded
2018/4/21:03:18:26 Fawzia Ehab LENOVO-PC Download User Play CMILM http://edutrial.autodesk.com/NET17SWDLD/2017/3DSMAX/WI/{AFF5571E-F691-448C-903A-A634A851AA7B}/CMILM....
2018/4/21:03:18:26 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
2018/4/21:03:18:27 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
2018/4/21:03:18:27 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2018/4/21:03:18:27 Fawzia Ehab LENOVO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
Your installation is failing due to the method you're using..
There's a couple of ways to properly download and install your Autodesk product to your machine. Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you. Open your log file using Windows Notepad and perform a search on "/SN". Depending on the number of installation attempts, your serial # may be located throughout the log file. If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
