When I click on the exe file to install Revit i get a dialog box that says "Something is preventing the software from downloading. Please contact your system administrator"
¡Resuelto! Ir a solución.
Resuelto por natasha.l. Ir a solución.
Hello @Anonymous,
If you are using the Install Now method of download that displays this error, you want to try a more reliable method called the Browser Download.
I have listed some steps to prepare your system for download and installation in case you run into a problem.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
HI @Anonymous
Have you seen the following AKN article about this error:
You want to try using the Browser Method from either your Account Manager or AVA
What version of Revit are you trying to install?
