Installation & Licensing
Error installing Flow Design
12 REPLIES 12
Message 1 of 13
5078 Views, 12 Replies
I am trying to install Flow Design in my laptop and getting an error in the very beginning. I use both the downloader and the stand-alone file and I get the same error.
Windows 8.1 pro 64bit
Lenovo G510
i7 - 4700qm
8gb  - ram
1tb - hard disk
* I have attached the installation log file.
12 REPLIES 12
Message 2 of 13
anybody to suggest any solution ? Man Surprised
Message 3 of 13
camilo.lemos
Hi @Anonymous ,
Please, follow the steps on this solution, it should solve the issue.
On a separate note, Flow Design is not supported on Windows 8.1, we cannot gurantee the program will work.
I hope this helps clarify the error.
Camilo Lemos
Message 4 of 13
how u solve the problems? i also encounter the same problem
Message 5 of 13
in reply to: camilo.lemos
Thanks !!! 😮
Message 6 of 13
hello, i have windows 10, still same error. cannot deal with this;( please help.
Message 7 of 13
Mark.Lancaster
@Anonymous
Welcome to the community.
Well the original poster had a 1603 error on a C++ installation..  Are you saying you have the same problem or that you received the dialog stated the installation finsihed but some products failed to install?   Meaning details are needed and not a simple statement I have same problem..
At this point we can only speculate what the issue is.  Post your installation log file so we can determine the issue.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Update:  Also are you trying to install Flow Design or another Autodesk Product?
Mark Lancaster
Message 8 of 13
I have recently tried installed flow design, I could install Autodesk® Simulation Moldflow Design, but " Autodesk® Flow Design " just doesn't install
(I am running on windows 10 )
It just starts installing then cuts off and jumps to " installation complete. Some products failed to install "
Message 9 of 13
@superjester11
Your installation is failing on Installing Microsoft Visual C++ 2012 Redistributable (x86).  My recommendation is to remove all Installing Microsoft Visual C++ versions (year and OS) in your Windows Control Panel/Program&Features/Add and Remove programs.  The installer will put them back on.  Good luck and report back on your progress.
Mark Lancaster
Message 10 of 13
That solved the problem, thank you for your help 🙂
Message 11 of 13
Thank you , this solved the problem !
Message 12 of 13
It also worked for me, thank you so much!
Message 13 of 13
100% OK.
Administrator Productivity
