Error installing AutoCAD 2017
Al iniciar por primera vez el programa me aparece un cuadro de dialogo como el siguiente, tiene alguna solución este problema? Adjunto imagen del problemaacad.png
Mark.Lancaster
@Anonymous
Welcome to the community..
This is an English speaking forum and we have no way of translating non-English message to understand what they are saying..  So keep that in mind..
However one of the words in that message I know what the message actually means..  Smiley Wink
See @TravisNave information >>here<<:
Mark Lancaster
natasha.l
Google Translate
When I start the program for the first time I get a dialog box like the following one, does any one have a solution to this problem? Attached image of the problem.
Hello @Anonymous,
If you are a student trying to access your free software please review this article to help guide you through the process: Steps for Setting-Up Student Software
Keep us posted on the progress. Smiley Happy
natasha.l
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue. Did any of the suggestions help?
tony1978
Here is a possible solution to fix this issue:
Solution
  1. Install Windows Updates:
    Go to Start - Control Panel - Windows Update
    Check for updates
    Install all available updates.
    After the updates are installed, restart your computer.
    After the restart repeat the steps above again until no more updates are available.
  2. Download the Visual C++ Redistributable:
    For Windows 64-bit
    Visual C++ Redistributable for Visual Studio 2015 (64-bit)
    For Windows 32-bit
    Visual C++ Redistributable for Visual Studio 2015 (32-bit)
  3. Run the vc_redist.x64.exe (64-bit) or vc_redist.x86.exe (32-bit) and select Uninstall
  4. Run the .exe again and select Install
_____________________________________________
Actualización para Universal C Runtime en Windows
Solución
Instalar actualizaciones de Windows:
Ir a Inicio - Panel de control - Windows Update
Buscar actualizaciones
Instale todas las actualizaciones disponibles.
Después de instalar las actualizaciones, reinicie el equipo.
Después de reiniciar, repita los pasos anteriores hasta que no haya más actualizaciones disponibles.
Descargue el Visual C ++ Redistributable:
Para Windows de 64 bits
Visual C ++ redistribuible para Visual Studio 2015 (64 bits)
Para Windows de 32 bits
Visual C ++ redistribuible para Visual Studio 2015 (32 bits)
Ejecute vc_redist.x64.exe (64 bits) o vc_redist.x86.exe (32 bits) y seleccione Desinstalar
Ejecute el .exe de nuevo y seleccione Instalar
Haz clic en el botón Aceptar como solución si mi publicación soluciona completamente tu problema o responde a tu pregunta.
 Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
