2017/2/23:12:42:02 Gautam GAUTAM-PC === Installation started on GAUTAM-PC by Gautam ===
2017/2/23:12:42:04 Gautam GAUTAM-PC Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 5.0.7601.18896
2017/2/23:12:42:04 Gautam GAUTAM-PC Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0
2017/2/23:12:42:04 Gautam GAUTAM-PC Install .NET Framework Runtime 2.0 Language Pack Skipped Installation not required
2017/2/23:12:42:44 Gautam GAUTAM-PC Install DirectX 9.0 Runtime Succeeded Command = "support\DirectX\DXSETUP.exe" /silent
2017/2/23:12:42:44 Gautam GAUTAM-PC Install MDAC 2.7 Skipped MDAC upgrade is not required. System Version = 6.1.7601.17514
2017/2/23:12:43:05 Gautam GAUTAM-PC Install Autodesk DWF Viewer Succeeded Command = "support\aev\DWFViewerSetup.exe" /u2 /q2 /b0
2017/2/23:12:43:06 Gautam GAUTAM-PC Install Flash Failed Failure is ignored, Result=1
2017/2/23:12:48:54 Gautam GAUTAM-PC Install AutoCAD 2007 Failed Installation aborted, Result=1603
2017/2/23:12:48:54 Gautam GAUTAM-PC === Installation ended ===
@Anonymous
Welcome to the community..
What operating system are you installing 2007 on? Why do you need such an old/retired/unsupported version? Where did you get this?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Welcome to the Autodesk Community.
I completely agree with Mark Lancaster.
you can get the most latest version (2017) of Autodesk AutoCAD free for 3 years. all you have to do is go to http://www.autodesk.com/education/free-software/featured
@Anonymous
Its great that you want to help out and provided answer (and its appreciated). But please make sure the solutions is kind of a solution. There's no indicated the original poster is even a student or even attend a qualified educational institution. So there are just not entitled to a free 3 yr student license.
Mark Lancaster
Thank you for the appreciation.
as you said, "There's no indicated the original poster is even a student or even attend a qualified educational institution." and that is right.
let's not say "So there are just not entitled to a free 3 yr student license."
instead, if I may say "if the 'potential users' are eligible as per the "Autodesk policy", they will get a free 3yrs Students, educators and educational institutions license.
Regards
Karan
Hello @er.gautam.taneja,
Thank you for your post, the operating system maybe considered unsupported for the product.
If you are using a newer/current operating system. It would be difficult to make it work, you can still try it.
Here is a link to the System requirements for AutoCAD 2007
Operating System for AutoCAD 2007
Microsoft Windows XP (Professional, Home Edition, or Tablet PC Edition), Windows 2000 Professional SP4
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
