i had this error installing the free trial of autocad 2018; before i had a 2013 version and i uninstalled all files/folders of that.
what can i do to solve this? could be a problem of missing file??
thanks.
When you start the software after you had installed it or did this error appear while installing?
I assume now it's raising while installing, so ....
Try the "direct download links" mentioned in >>>that thread<<< and when you have downloaded all setup files to your local drive make sure Antivirus is turned off, and start the first of the file with right-click and "start as administrator".
Good luck, - alfred -
Yes is during the installation phase, I'll try also this method and I'll let you know if it works.
Thanks.
Greetings, Luca
Hello @luca.sarti8VFW7,
Thank you for taking part in the community, I understand you are having issues installing your software. Please provide us with some more information by locating the Windows TEMP folder. You can do this by going to the Windows Start > type Run in the search box (shortcut Win.key+R) and typing %TEMP% into the box and clicking OK.
Sort by Date or Name and find the Autodesk product and save the installation .log file. Please attach this log file to your reply.
This will help us determine the possible issue preventing you from installing your software.
Note: Log files sometimes contain private information such as serial numbers, please remove this information.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
