Error every time try to install auto cad or revit
Hi there, every time I try to install autocad or revit (student versions) this error comes up and I cannot install. What is causing this? How can I fix this? Thank you in advance.
mpeperkamp
Hi @Anonymous,
Welcome to the Autodesk forum.
I hope that following your help:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Install-complete-Some-Products-Failed-to-Install.html
If you have any questions let me know.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Alexander.Rivilis
@Anonymous
Very often this error is due to the fact that part of installation package can not been downloaded. So try to use Autodesk Virtual Agent in order to download and install.
Instruction:  Installing Autodesk products from the Virtual Agent
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
