Received Error when i am trying to install Maya on Ubuntu 16.04
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Not a Maya user/expert along with not being a user of ubuntu..
Review this: http://lost-triangle.com/2016/09/05/install-maya-2017-on-ubuntu-16-04/
Also just keep in mind ubuntu is not a typically operating system that gets supported on this forum.
Mark Lancaster
& Autodesk Services MarketPlace Provider
The link does not work... I still have this issue! I can't find a solution anywhere
You have to convert the .rpm packages to .deb packages using alien like so
sudo alien -cv *.rpm
Then install the packages using dpkg
sudo dpkg -i *.deb
Be sure to install all the requirements along the way good luck.
I converted the rpm files into deb files and unpacked the deb files, but still the error occurs and the installation fail, any help?
