Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
Error code 1603 when installing Inventor 2021
5 RESPUESTAS 5
RESUELTAS
Responder
Mensaje 1 de 6
1091 Vistas, 5 Respuestas
Hi all,
I cannot seem to get Inventor 2021 (education version) to install after a fresh windows install and partial data recovery on a drive.
I have tried clearing the TEMP folder and deleting all autodesk files on the drive I am installing on.
I even tried installing 2020 and 2019 and they did not work. I have attached log files from when I tried to install it both with and without the content library so if anyone is able to decode what is written in there.
Etiquetas (1)
Etiquetas (5)
5 RESPUESTAS 5
Mensaje 2 de 6
leowarren34
en respuesta a: Anonymous
Hi @Anonymous,
Have you tried using the browser download method? It tends to be more reliable, the downloads can be found at http://manage.autodesk.com/ -> products and services -> Inventor -> Downloads. 3 files should download, if not disable your popup blocker, run them as admin.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Mensaje 3 de 6
Mark.Lancaster
@Anonymous
It appears the licensing mechanism is not installed properly or didn't start.
Can you confirm if this Windows service is there and started
Mark Lancaster
Mensaje 4 de 6
en respuesta a: Mark.Lancaster
@Mark.Lancaster, Thanks for the reply, seems it is not installed and when I try to install it, it doesn't work, just the pop up "are you sure" that windows does then I hit yes then it has the loading wheel for a second or two then it stops
Mensaje 5 de 6
Mark.Lancaster
@Anonymous
What are you trying to install or load?  The licensing mechanism?
Mark Lancaster
Mensaje 6 de 6
I figured out a solution, I still had an old folder in my %appdata% folder I think.
I searched through both drives on my computer for "autodesk" and deleted everything.
Publicar en los foros
Administrator Productivity
