Error 270 during installation
maagdaaa18
maagdaaa18
when I try to install Revit 2023 I get following error: Error 270 Instalation cannot be finished. Couple of time I have tried install product again and again but it still does not work. Installation process usualy end at 20%, but like programs such as Autodesk Material Library 2023 or Autodesk Revit Unit Schemas 2023 got installed. I also tried to install another program (Robot 2023) but I had received the same result. I attatched screenshots.
I use educational license, my hardware is compatiblity with requirements and I have enough space on my disk to properly instalation.
I also contacted with Support but I have not got any answer so far.
I would be grateful for your help.
pendean
Community Legend
Community Legend
maagdaaa18
Finally got worked. I had to find out and remove any file on my PC from Autodesk and clean up Windows Registry. Issue solved so topic can be closed.
luc.nguyen3THET
Community Visitor
Community Visitor
please share me the solution
abdel_zakaria
Community Visitor
Community Visitor
Disable antivirus/firewall: Sometimes antivirus or firewall software can interfere with the installation process. Temporarily disable them and try installing the software again.
arkmagg
Community Visitor
Community Visitor
for 2024 versions...delete all folders and trace of Autodesk components from your computer, restart and try again
