Error 1935 when installing Revit 2018
manalkhalil
manalkhalil
 does any one face this problem in revit installation ? how can i fic it ?ERROR.jpg
@manalkhalil
Topic Title has been changed by @Tiana_Y for better findability. Original Post: installation problem
leowarren34
Hi @manalkhalil,
Error 1935 is for corrupted Visual C++ components - which makes sense as the installer was on the Visual C++ Component install.
If you uninstall the Microsoft Visual C++ Components and then reinstall as it would in the Revit Installer then that should fix your problem.
A full step by step guide can be found here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
mdavis22569
Hi @manalkhalil
Have you seen the following AKN article about this issue:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-1935-An-error-occu...
Mike Davis
manalkhalil
😀it works , thanks
