I have key and licsence #, but I am unable to install. continue to receive ERROR 1619.
Please HELP!
Welcome to the community. Please post your installation log here and I will take a look.
Thanks!
I have attached a log of my attempts to Setup.
Very frustrated. assignment due on this Thursday. Please help.
Can you access my computer remotely to install?
Thank you!
No sorry, this is just a peer support group.
Looks to be failing on the language pack.
Install Autodesk® Revit® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
Are you installing in English on a US-English PC?
You might try installing it manually and see if it still errors:
You might also try a new clean download altogether.
If the above still fails, I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
I will give all options a try.
I hope the first one works.
Thank you
Happpy Mardi Gras!
Yes me too! And thanks! I forgot it was Mardi Gras!!!
I have never recommended the Language Pack fix directly before, so I can't guarantee success. But download problems are almost always resolved using the virtual agent. One way or another, I hope you get installed.
