Installation & Licensing
393 Views, 5 Replies
ERROR 1619 student
I have key and licsence #, but I am unable to install. continue to receive ERROR 1619.
Please HELP!
5 REPLIES 5
TravisNave
Welcome to the community.  Please post your installation log here and I will take a look.
Thanks!
Autodesk Forums:
in reply to: TravisNave
I have attached a log of my attempts to Setup.
Very frustrated. assignment due on this Thursday. Please help.
Can you access my computer remotely to install?
Thank you!
TravisNave
No sorry, this is just a peer support group.
Looks to be failing on the language pack.
Install	Autodesk® Revit® 2015 Language Pack	Failed	Download Failed, Installation aborted, Result=1603
 Are you installing in English on a US-English PC?
You might try installing it manually and see if it still errors:
http://download.autodesk.com/us/support/files/revit_2015_language_packs/Autodesk_Revit_2015_English_...
You might also try a new clean download altogether.
If the above still fails, I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
I will give all options a try.
I hope the first one works.
Thank you
Happpy Mardi Gras!
TravisNave
Yes me too!  And thanks!  I forgot it was Mardi Gras!!!
I have never recommended the Language Pack fix directly before, so I can't guarantee success.  But download problems are almost always resolved using the virtual agent.  One way or another, I hope you get installed.
Smiley Happy
Autodesk Forums:
Administrator Productivity
