Error 1603 for Revit 2020 and AutoCAD 2020
abblomquist
abblomquist
I'm unable to install Revit 2020 or AutoCAD 2020. I was able to get NavisWorks Manage to install this morning but nothing else. Here are my log files. I've tried a few of the solutions here
Any tricks to uploading log files? I get this neat message "The attachment's autodesk revit 2020 setup.log content type (application/octet-stream) does not match its file extension and has been removed."
Replies (24)
Mark.Lancaster
@abblomquist
You may want to follow the steps that I'm outlining in this posting https://forums.autodesk.com/t5/installation-licensing/revit-2020-installation-failure-code-1603/m-p/...
Mark Lancaster
abblomquist
I see the same thing as csmock here "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\" but I don't have the "Autodesk Desktop Licensing Service" to attempt to start.
abblomquist
@Mark.Lancaster Any ideas if I'm missing that Service?
Mark.Lancaster
@abblomquist
Do you see the uninstaller.exe in this folder C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing
If so run it..  Then under the installation media run this C:\Autodesk\<Autodesk Product>\x86\AdskLicensing\AdskLicensing-installer.exe
Is the service there now?
Mark Lancaster
abblomquist
@Mark.Lancaster
No, it still isn't there. Here is the end of the log file
abblomquist
@Mark.Lancaster anything for me to try? Otherwise, I'll call support today to see if they can assist. Thanks, Andy
Mark.Lancaster
@abblomquist
Based on what I'm seeing you account doesn't allow the service to start or be installed.   Can you run the license service installer with full admin rights.  Disable UAC and Anti-Virus.
Mark Lancaster
abblomquist
@Mark.Lancaster I uninstalled AV and turned UAC and still the same thing errors on the Service.
Mark.Lancaster
@abblomquist
Perhaps you may want to try this on an admin command prompt
https://forums.autodesk.com/t5/installation-licensing/how-to-reset-autodesk-2020-licensing/m-p/87810...
And if you see the same results you may want to see this https://forums.autodesk.com/t5/installation-licensing/how-to-reset-autodesk-2020-licensing/m-p/88029...
Or let us know if you see something else..
Mark Lancaster
abblomquist
@Mark.Lancaster OK, so now it appears the issue is with that "Current" folder. When I attempt to open that it tells me "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current is not accessible. The filename, directory name, or volume label syntax is incorrect."
Mark.Lancaster
@abblomquist
Current folder?   Why are you going into the "CURRENT" folder?
Mark Lancaster
abblomquist
Mark.Lancaster
@abblomquist
Oh..   You were doing other stuff that I didn't ask for you to try.   I only pointed you to specific spots in that discussion for you to try.
Mark Lancaster
abblomquist
@Mark.Lancaster sorry, I got to reading the article. If I go to that specific spot it appears to run fine but doesn't show up under Services
abblomquist
@Mark.Lancaster FYI it is still running today. Also, Autodesk support is bad. The "tech" I say that loosely as he has a script and doesn't deviate from it. Doesn't appear to have much knowledge with the product as that script appears to be as far as it goes. Have to wait 24-48 hours for it to escalate.
m_latz
Can you post a screenshot from your C:\Program Files(x86)\Common Files\Autodesk Shared\AdskLicensing folder.
Here is a screenshot from my computer:
regards
Markus
m_latz
Next please check this:
Just that you can paste easy to your cmd window:
"C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\9.0.1.1462\helper\AdskLicensingInstHelper.exe" upgrade isUpgraded
regards
Markus
abblomquist
@m_latz @Mark.Lancaster here is my what my folder looks like
and here is the command.
This seems to be related but might not be if I try to open the "Current" folder this is what I get
m_latz
Okay, and this is definitely a problem, because:
"C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe"
should also work.
What operating system do you have ?
Have you UAC enabled, was it enabled during the install of Navisworks 2020 ?
Has you user admin rights ?
regards
Markus
