error 10
error 10
error 10
Ho Comprato AutoCAD LT 2007 n seriale: xxx-xxxxxxxx da un mio Cliente perchè lui ha installato la versione 2010. in fase di Installazione mi da Errore 10. Cosa devo fare?
Ho comprato AutoCAD LT 2007 Numero di serie: xxx-xxxxxxxx dal mio cliente perché ha installato la versione 2010 in fase di installazione mi dice errore 10. Cosa devo fare?
Otto
Hello momoimpianti and welcome to the Autodesk community!
It looks like you're getting Error 10 during activation. This error typically occurs because our systems detected more attempts to activate the software than is allowed by your license. The following article(s) should help you resolve the problem:
Unable to activate product due to Error 10: Activation Limit Reached error
The software license failed to initialize. Error 10
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
When did you buy  AutoCAD LT 2007?  This is a 10 yr product and no longer sold, support and etc. Just because you bought this recently through other means doesn't mean its going to activate.  In the end you most likely wasted your money...  Smiley Wink
Also when your posting is translated to English this is what we get "I Bought AutoCAD LT 2007 Serial No: xxx-xxxxxxxx by my client because he has installed the 2010 version being me Installation Error 10. What should I do?"  This makes no sense of what's going on..  Can you clarify.
Also if you typed in your serial # (it looks like it got caught and changed)..  Please don't do that..  This is a world wide user forum.
Mark Lancaster
Darin.Green
Upgrade!
If this information was helpful, please consider using the Accept Solution
natasha.l
Google Translate
Hello @Anonymous,
Thank you for your post, if you are using a somewhat current operating system it is probably considered unsupported for the product.
In some cases, it will work and in others, it hasn't. The requirements mean it has not been tested to run on a system that is not listed in the system requirements.
Please review this link to make sure it is supported for AutoCAD LT 2007  system requirements
