empty zip file
empty zip file
shanpowell
Observer Observer
empty zip file
shanpowell
Observer
Observer
Steps to reproduce
"How to simulate quick and accurate traffic flows" on-demand module resource zip file is empty. CE-CBA0003_R_H Conceptual Dataset.zip - (32 mb)
Expected results
These downloadable resources will be used to complete units in this module:
Actual results
"Cannot Complete the Compressed (zipped) Folders Extraction Wizard
The compressed (zipped) folder is empty.
Before you can extract files, you must copy
files to this compressed (zipped) folder.
To close this wizard, click Finish."
URL where issue occurs
https://www.autodesk.com/learn/ondemand/module/how-to-simulate-quick-and-accurate-traffic-flows
Browser
Chrome
OS
Windows
TravisNave
It does seem to be corrupted with regular zip methods. But I found that 7.zip will upzip the file.  You can download it here and then right-click and open the archive.  That will get you to the files.
https://www.7-zip.org/
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
