Installation & Licensing
S.MANICKAVASAGAM
337 Views, 4 Replies
Email
Dear Expert,
                 Can be changed my Email id and keep my same account?
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Tags (2)
Labels (1)
4 REPLIES 4
Pretty sure you can change your email under your account security settings.
https://profile.autodesk.com/security
It will require you to login again for verification before changing your email.
Autodesk Forums:
BIM Auto Design
we hava a structure mode with soild math , and it's irregular and a part of it change , like size, the others will change ,too ,we need calculate angle and scale
Tags (1)
@13313636962
It looks like you're on an email thread.
Have you seen the following forum:  https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
I think this might be what you're looking for. They should be able to help with this.
I see you posted here as well:  https://forums.autodesk.com/t5/autocad-forum/bim-auto-design/m-p/12845832
Mike Davis
Jackace7766
in reply to: mdavis22569
@mdavis22569 wrote:
@13313636962
Thanks, It is helpful.
Administrator Productivity
