Educational License not recognized by Revit 2020
I need help.  I have an educational license. I downloaded Revit and it was working fine. I began to get these "SYSTEM MAINTENANCE Sorry something went wrong on our end" pop up boxes. I closed and moved on. Then it stopped working and I got the "Licensing Manager not functioning properly" error and Revit doesn't open. I have contacted customer support and they told me to update my software via Autodesk app. Still not working. Then, I followed the uninstall/ reinstall steps. Didn't fix.  I followed the clean uninstall/reinstall steps. I ran the Microsoft trouble uninstall/install program. I downloaded the updates - including the license update. Still didn't work.
I even reset my laptop, reinstalled AutoCad and Revit. AutoCAD opened fine after entering my Autodesk user info.  Before I even opened Revit, I downloaded all the Revit updates from the Autodesk app (in order) - including the license update. I even checked the Console Certificates to make sure all the appropriate files were there.
When I open Revit I get a the same problem - a System Maintenance box. There are two options available to click on..."Help me understand..." and " Already Have a license?"
HELP ME UNDERSTAND - Basically tells me my trial version time is up.
ALREADY HAVE A LICENSE - Give me three options: Switch User - Enter a Serial Number - Use Network License.
[see attachment]
Through my educational account, I can find my AutoCAD serial number, but there is no Revit number listed.
I have reinstalled Revit THREE TIMES!
When I sign into Autodesk account online, My Products & Services shows a list of software available. Right at the top is the AutoCAD I just downloaded. There are a dozen more apps listed (ReCap, Fusion 360, Remake, etc) but no Revit.
Sincerely at my wits end!
I was approved for an educational license. Revit is on the "list" for educational licenses.
leowarren34
Hi @Anonymous,
Have you requested a Revit License from https://www.autodesk.com/education/edu-software/overview
Licenses are not granted automatically and must be requested yourself, you can check any licenses you have since they will appear at https://manage.autodesk.com/ under products and services.
If you still fail to get a license for Revit then reach out to Educational support: https://www.autodesk.com/education/support
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" /><meta name="Generator" content="Microsoft Word 15 (filtered medium)" /><!--<br>/* Font Definitions */<br>@font-face<br> {font-family:"Cambria Math";<br> panose-1:2 4 5 3 5 4 6 3 2 4;}<br>@font-face<br> {font-family:Calibri;<br> panose-1:2 15 5 2 2 2 4 3 2 4;}<br>/* Style Definitions */<br>p.MsoNormal, li.MsoNormal, div.MsoNormal<br> {margin:0in;<br> font-size:11.0pt;<br> font-family:"Calibri",sans-serif;}<br>a:link, span.MsoHyperlink<br> {mso-style-priority:99;<br> color:blue;<br> text-decoration:underline;}<br>.MsoChpDefault<br> {mso-style-type:export-only;}<br>@page WordSection1<br> {size:8.5in 11.0in;<br> margin:1.0in 1.0in 1.0in 1.0in;}<br>div.WordSection1<br> {page:WordSection1;}<br><br>
