Educational Access
Educational Access
Educational Access
Hello!
I've had my account for a while and from what i understand its an educational one seeing as I'm able to use AutoCAD 2021 without a problem.
I recently downloaded Revit 2021 and it seemed fine at first until I realized it was a trial version. When I try to activate it, it asks for a serial number which I did not received.
I thought my account had to re-confirm my eligibility but I see no option to do so on the site. All I see when I open the Education Community tab is, "Hi Jaycob! Your educational access to Autodesk is valid through--. Choose a product below."
Is there a way to fix this?
-Jaycob
RDAOU
@Anonymous
You do not need to finish the download and you do not need to reinstall...just re-launch Revit 2021 which you have and switch license to Log In using user account
leowarren34
Hi @Anonymous,
I've seen this issue with the 'valid through --' before and it seems to be an issue on Autodesk's side as if your license has expired, it stops you from renewing.
Reach out to educational support: https://knowledge.autodesk.com/contact-support
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
