Is it possible to install DWG TrueView 2015 for "All Users" on a machine?
We are trying to deploy DWG TrueView (Windows 7 - x86 and x64) via SCCM.
The installation runs as the local System account. We've also done manual installations, and the same issue occurs - we've run as Administrator, local admins, non admins...
I've tried a few methods of install strings which all install correctly, from running the setup.exe silently with the setup.ini, to using the dwgviewr.msi.
I even modified the .msi, setting ALLUSERS to 1 (it was set to 2)
The install works fine for the user who installed the application.
However, when other users login they get the message:
"Run Setup.exe to install DWG TrueView 2015 - English"
They can then go and open the application - it does run with no problems, but the pop up runs every time they login.
If a user runs the setup.exe (admin or not) - it states the product is already correctly installed and nothing else can be done.
Am I missing something glaringly obvious here?
