I am working on a drawing that has a combination of "Drawing Views" - Mader from the new Layout tools (Viewbase, Sections and Details) - However I also have traditional viewports on the same Layout. - I am unable to get the viewports to publish.....Are they incompatible on the same Layout Tab?
Why?
I have also just discovered that the Drawing Views are not backward compatible with previous releases (They cannot be edited or updated....) even when saved back to the same .dwg version. - I did not see this in any of the previous documentation - Only found it in the 2015 documentation...
Again why? - This was a very painful and disappointing discovery....perhaps it was documented and I just miussed it, but this is a HUGE liability and should have been more urgently advertized. Disapointing!
Chuck
this is the installation and licensing forum
you need to post in the correct product forum since you don't say what product your using i can't point you to the correct one
http://forums.autodesk.com/t5/custom/page/page-id/Discussions-Page
