I've been trying to download Revit 2021 but it's not working. It says "Product download consists of multiple files. At least one file is missing or has not been downloaded yet"... any advice? Won't allow me to "install" either.
Hi @Anonymous,
This is probably due to your pop-up & redirects blocker preventing you from downloading all of the files, there should be 6 in total for Revit.
Long term you should update your pop up & redirect settings for your browser, for Chrome this is:
Click on the padlock on the search bar -> Site Settings (on the manage website) -> Pop-ups and redirects -> Allow
Otherwise, here are the direct download links:
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_001_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_002_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_003_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_004_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_005_006.sfx.exe
https://edutrial.autodesk.com/NetSWDLD/2021/RVT/5A103FCF-A48C-4B74-A1FB-3B46BAE71CE5/SFX/Revit_2021_G1_Win_64bit_dlm_006_006.sfx.exe
"Good afternoon, could you please share the link to download the 2021 version of Revit? I need that specific version because I am working in collaboration, and it is the one being used."
I guess you missed the message above containing the links to the needed files?
If you have a current subscription, you should just be able to do the following:
Hi
I am trying to download revit 2021 and none of the above links are working, it keeps saying that there are some files missing could someone maybe share a link to the download page instead of direct download links if possible.
Have you seen the following Autodesk article:
https://www.autodesk.com/support/download-install/individuals/configure/download-older-versions
Like this...
That's great to hear @ak6133377
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
