I purchased 2 AutoCAD 2016 licenses for my company through autodesk that we never activated. I'm trying to figure out how i can download AutoCAD 2016 and then use my serial numbers to activate it...?
Brad
Solved by natasha.l. Go to Solution.
Go to your subscription center (https://manage.autodesk.com), there you find the download link(s) as well as the serials.
- alfred -
It looks like your reply got separated from the original posting..
@Discussion_Admin please take a look at this separation..
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Almost 3 years later you want to start using them... Did you use those license to upgrade at any time?
Mark Lancaster
@Anonymous
@pendean already provided that info or in a formal reply..
There's a couple of ways to properly download and install your Autodesk product to your machine. Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you. Open your log file using Windows Notepad and perform a search on "/SN". Depending on the number of installation attempts, your serial # may be located throughout the log file. If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
Hello @Anonymous,
Thank you for being a member of the community.
The community provided you with two options, where you can locate the download it is available through your Autodesk Account or AVA the virtual agent.
You first want to prepare your system for a download & install, here are some simple steps to take.
Let us know if you need anything else.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
Just checking in with you, hope you were able to download & install AutoCAD 2016 version? Please let us know
& "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Helpful Links:
