DLL RapidRTRenderer.dlr failed to initialize - error code 127
Dear Madam, Sir,
After using 3DStudio Max 2016 for 10 months without problems, I now get the following message when starting 3DStudio Max:
DLL <C:\Program Files\Autodesk\3ds Max 2016\stdplugs\RapidRTRenderer.dlr> failed to initialize. Error code 127 - The specified procedure could not be found.
I uninstalled 3DStudio Max 2016 and installed it again. The installation was succesfull. After starting Max again, I got the same message.
Please advice how to proceed.
Many thanks,
Henri Achten
Otto
Hello Henri_FA_CVUT and welcome to the Autodesk community!
It looks like you are seeing Error 127. The following article(s) should help you resolve the problem:
How to reset AutoCAD to defaults
Alternatively, please make sure you have the latest service pack installed before attempting to install the software.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Thank you for the reply, but my problem is with 3DStudio Max 2016, not with AutoCAD.
ioannis_olav
hahaha 🙂
Just encountered the same issue with a mentalray.dlz missing.
I ll give it a shot to reset Max though see if that solves it
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Resett...
natasha.l
Hello @Anonymous,
Please try to follow that steps for uninstalling the current plugin & install mental ray from your Autodesk account. Make sure to use the correct plugin version & to review the More Options > View Details > Release Notes.
Thank you for posting. Smiley Happy
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
